GregFlynn
Car 12 volt supply
Thu Feb 28, 2013 8:54 pm
Hi
Can anyone confirm if I can use a 12 volt supply from my car wiring to power the Rasberry Pi.
If so, can you recommend a specific power supply
Thanks in advance
Greg
dasimpson
Re: Car 12 volt supply
Thu Feb 28, 2013 9:34 pm
you would need to bring the 12v down to 5v
2 options one wasts a lot of power as heat and the other no waste at at all
the first option is the LM7805 REGULATOR wats a lot of power and produces a lot of heat would need a heatsink
option 2 ubec (Universal Battery Elimination Circuit) very efficient no waste all
myself I would go for option 2
jazzy
Thu Feb 28, 2013 11:50 pm
why not use a phone charger cigarette lighter adapter
pjc123
Fri Mar 01, 2013 12:10 pm
jazzy wrote:why not use a phone charger cigarette lighter adapter
This is what I am using. I have a dual port cigarette lighter adapter with two USB outputs, one 2.5 amps and one 1 amp. I actually use both outputs because I have a lot of external circuitry to control.
My Raspberry Pi Project Page:
https://www.flaminghellmet.com/launch/
dasimpson
Fri Mar 01, 2013 6:06 pm
cos most of the simple car one use a LM7805 REGULATOR also he might wont all wireing out of site
