sim_tcr
Anyone tried or familiar with "Gate One" (web based SSH)?
Tue Feb 26, 2013 5:32 pm
Any one here tried or familiar with "Gate One" https://github.com/liftoff/GateOne ? It is used for web based ssh connection to your pi.
Basically if you install it on your pi and you got a web server running, when you are outside you are home you can ssh in to your pi using your web site address. its kind of embedded terminal.
I was able to install and run it successfully. However my pi is setup for ssh-key based authentication. I dont know how to configure Gate One for my ssh-key file.
Thanks,
Simon Mandy
http://raspisimon.no-ip.org
Raspberry Pi Model B x 2, Raspberry Pi 2 x 2, Transcend 32GB Class 10, Transcend 16GB Class 10, Transcend 8GB Class 4, Custom 12V 1.5A (stepped down to 5.5V)
bscardin
Re: Anyone tried or familiar with "Gate One" (web based SSH)
Thu Feb 28, 2013 2:38 pm
Click the magnifying glass icon on the GateOne page. Under the SSH Plugin click Manage Identities. You can either generate or upload a key. I had trouble generating a key using GateOne so I uploaded my own private key. Then check the box next to the identity and that key will be used for the ssh session.
