how do you get ubuntu on pi
Posted: Sun Feb 24, 2013 4:53 pm
by thebic4
can i be directed to a video, blog, post, or guide on how to put ubuntu on my pi please?
Re: how do you get ubuntu on pi
Posted: Sun Feb 24, 2013 5:06 pm
by leol
I don't believe it is possible as Ubuntu has not been ported to the right version of ARM.
Posted: Sun Feb 24, 2013 5:15 pm
by redhawk
Ubuntu is based on Debian the same as Raspbian which is also based on Debian and specifically optimised for the Pi.
As already pointed out there's no ARM v6 port of Ubuntu so a skinned Raspbian is about as close as you'll get.
Richard S.
Posted: Sun Feb 24, 2013 5:20 pm
by Cloudcentric
Raspbian "wheezy" has the look and feel of Lubuntu.
There are several ways to change wallpapers and skins etal on Wheezy
The Unity Ubuntu Desktop Environment is far too resource hungry......................
Posted: Sun Feb 24, 2013 5:22 pm
by JeremyF
Raspbian has all the same essential features.
What features of Ubuntu do you feel are not present, but necessary/wanted, in Raspbian? We can certainly help you with that. Just not porting an entire operating system.
Posted: Sun Feb 24, 2013 7:36 pm
by tonyhughes
I'm an Ubuntu user on my x86 boxes.
I had previously used RedHat (back in the 3.x days), Mandrake (Mandriva now I think), FreeBSD, and Fedora.
Ubuntu is 'comfortable', but since the Raspberry Pi, and Raspbian, I am fairly convinced that Debian itself will become my 'go-to' distro.
Raspbian is great, and really stunningly close to Ubuntu because of that shared ancestry of Debian.
As others say - what do you want Ubuntu to do, Raspbian can probably do it.
Posted: Sun Feb 24, 2013 8:57 pm
by Jim Manley
The Foundation had originally intended to use Ubuntu and, IIRC, had some portion of Ubuntu 9.0.4 running on some pre-production boards, but never made it available. Ubuntu 9.0.4 is the last distribution to support ARM v6 microprocessors as used on the Pi and the Foundation moved to Debian when the Ubuntu team stated that they would not be supporting ARM v6 beyond 9.0.4. The Ubuntu team is dedicating all of its resources to supporting ARM v7 and beyond due to multi-core features (Coretex) that can be available in those processors, but not in ARM v6 devices.
Raspbian is a perfectly fine distribution for use on the Pi, even for beginners for whom Ubuntu was originally developed. It includes a lightweight GUI/desktop, browsers, IDEs, and other software best suited for the capabilities of the Pi's ARM v6 CPU, FPU, RAM, SD card storage, etc. The current Ubuntu distribution would never be able to run on the Pi anyway, even if ARM v6 were supported. It requires far more resources than the Pi can provide - 1 GHz+ clock speed, 64-bit data and address buses preferred, multi-core preferred, 1 GB+ of RAM, tens of GBs of disk space, etc., and those are x86 specs - ARM specs would be even greater to achieve the same performance.
Posted: Sun Mar 17, 2013 6:35 am
by gf42
Jim Manley wrote:The Foundation had originally intended to use Ubuntu and, IIRC, had some portion of Ubuntu 9.0.4 running on some pre-production boards, but never made it available. Ubuntu 9.0.4 is the last distribution to support ARM v6 microprocessors as used on the Pi and the Foundation moved to Debian when the Ubuntu team stated that they would not be supporting ARM v6 beyond 9.0.4.
Sorry to revive an old thread but I just got 9.04 for armv6 that should all work.
http://www.raspberrypi.org/phpBB3/viewt ... 1&p=311472
Guy
