timmoore46
Bash script works but strange message
Sat Feb 23, 2013 6:22 pm
I'm trying to use a sort of 'and' function but I'm a rank newbie to BASH
This is the truth table I'm attempting to simulare in the scipt:-
Inputs outputs an altered y called d
y z d
0 0 0
0 1 1
1 0 1
1 1 1
and it works.....
#! /bin/sh
# 23/2/13
# chmod a+x logic_003
# control c stops the program
# using font 'DejaVu Sans Mono'
while true
do
#setup Input
echo "y?"
read y
echo "z?"
read "z"
if [ $y -eq 0 ]
then a=0
# a dummy only
else
if [$z -eq 0 ]
then y=0
else y=1
fi
fi
echo "y is :-"
echo $y
echo "z is:- "
echo $z
echo " end of logic section"
sleep 3
echo " "
continue
done
______________________
But it offers an error message;-
./logic_003: 57: /./logic_003: [0: not found (for y=1 and z=0 input)
./logic_003: 57: /./logic_003: [1: not found (for y=1 and z=1 input)
____________________________________
Anybody and ideas what this message is about ?
I know I'm an idiot but ar least I'm trying to get BASH do do something useful !
Any ideas anyone... ???
Tim
jojopi
Re: Bash script works but strange message
Sat Feb 23, 2013 7:05 pm
"[" is just a silly name for the command "test". Because it is the name of a command, and not a feature of the language syntax, there must be a space between the "[" and its arguments. If you miss the space out, like "if [$z", you try to run the command "[0", which does not exist.
In my opinion it is clearer just to write:
if test "$z" -eq 0; then
DBryant
Sat Feb 23, 2013 7:44 pm
Bash syntax is:
If [ conditional expression1 ]
then
	statement1
	statement2
elif [ conditional expression2 ]
then
	statement3
	statement4
else
	statement5
fi
I think you must have a space after the [ and one before the ] too.
Seems to work when I tried it
totoharibo
Sat Feb 23, 2013 8:41 pm
at the same time try read z not read "z"
timmoore46
Sun Feb 24, 2013 7:31 am
Many many thanks ! I really appreciate all your support !
I will amend my script and see if it behaves better !
A very happy,
:D
Tim
DBryant
Sun Feb 24, 2013 9:39 am
Just a note on the use of [.
[ is a binary, run
ls -la /usr/bin | more
but just strangely named. You can see why that space is required, after all if if were call test, you would expect 'test$z' (no space) to be different from 'test $z'.
So [ (aka test) reads its arguments are does its job. The last argument (the closing ]), it simply ignores; so there is no need for a /usr/bin/]. But it too will require a space in front of it, simply because that's how arguments are separated in a shell.
And 'read z' if no different from 'read "z"', wouldn't expect if to be and it isn't in reality. However if you're new to scripting then you might want to get into the habit of enclosing strings in quotes, for example
name="Dave Bryant"
printf "%s\n" $name
Dave
Bryant
printf "%s\n" "$name"
Dave Bryant
with quotes the string is printed correctly as a single arg, without it is treated as two args.
timmoore46
Sun Feb 24, 2013 6:26 pm
Well, my logic is a bit off, but what concerns me now is how to pass the information to a 'log' file, so I can go back and look at it.
I've added 'date' to it so I've got a real time record of events,,,,,,
any ideas anyone ?
:D :D :D
Tim
DBryant
Sun Feb 24, 2013 8:15 pm
Constructs like
logFile="~/scriptLogFie.txt"
echo "$(date): Initial log record" >> $logFile
might do what you want. The >> appends the result of the echo to the specified file.
If you want to null the file at the start of the script then either of these lines at the start would do
cat /dev/null >> $logFile
echo "$(date): Initial log record" > $logFile
Note the single > in the last case.
These examples are re-directing the script's stdout to a file. There is also stderr to consider which can be routed to the same file, or to a specific error file, different from the log. But that might be more thatn you want at this point in time.
Alternatively there is the logger utility that wil inject log records into /var/log/message via UNIXs standard logger daemon - see http://unixhelp.ed.ac.uk/CGI/man-cgi?logger+1 for detail. This is more advanced but puts information into an established logging stream.
timmoore46
Sun Feb 24, 2013 9:19 pm
Wow ! Mega Brilliant ! At this stage the simplest solution is the best ! Occam was right ! *LOL*
That was exactly what I needed ! Apart from a Tardis ! Time always is tricky ! *LOL*
:D :D :D :D :D :D
Tim
jojopi
Sun Feb 24, 2013 9:45 pm
DBryant wrote:cat /dev/null >> $logFile
That does nothing. It does write nothing to the file, but you opened the file for appending, so the existing contents remain. The canonical way to truncate a file to zero bytes is:
: > $logFile
Here, ":" is a silly name for "true", which produces no output.
By the way, in scripts it is better to use "$HOME" instead of "~". "~" works in most shells, but it is non-standard.
timmoore46
Mon Feb 25, 2013 7:37 am
I tried this:-
logfile="test.log"
echo "$date" >> $test.log
and it does not work.
Obviously I'm missed something vital !
Tim
DBryant
Mon Feb 25, 2013 7:55 am
Clue: Look where your re-directing the output to!
I defined a variable, initialised to the name of a file; something you might put at the top of the script and re-use through the script. Then you re-direct to that; you've re-written the name of the file, prepended with a dollar, as if its a variable. Bash good not this is. Take another at the first code block in my earlier posting.
There was a typo in that first posting; to null a file then it should have be a single > as in
cat /dev/null > $logFile
Yes, there are other ways of doing this (as in ': > $logFile'), one just have to decide what is your comfortable way of doing things. As this stage, less cryptic looks a better way to go. But then one man's cryptic is another man's ... Fortunately (or not) coding standards are unenforced in the home brew domain. ;)
timmoore46
Mon Feb 25, 2013 6:05 pm
Wow ! removed the $ from the 2nd line and it worked !
Many many thanks! Especially for your patience.
As you can tell my understanding of BASH is close to non existent !
I'll play with this and see if I can get work in my mail control program !
:D :D :D :D :D :D
Tim
timmoore46
Mon Feb 25, 2013 6:19 pm
logfile="control_004.log"
echo "$(date)" >>control_004.log
date
saves the date stamp fine.
The next challenge is to get anything sent to the console into the logfile too...
:D :D :D :D :D
Tim
DBryant
Mon Feb 25, 2013 7:23 pm
You've not got it have you!
The logFile variable , as you use it, is totally redundant because you don't use it!
Your code should be this exaclty:
echo "$(date)" >> $logFile
The assumption was that you would have many log records written in your script. In this scenario, if you decide to call the logfile something else, you just have to change one line (nicely poistioned at the top of the script). Otherwise you'd have to find everying log line and edit if with the new name.
You need to look tee, see http://unixhelp.ed.ac.uk/CGI/man-cgi?tee.
So in your case
echo "$(date)" | tee -a  $logFile
the -a is important so as to append rather than overwrite.
timmoore46
Mon Feb 25, 2013 8:01 pm
Many thanks again, especially for your patience !
I will try it out tomorrow.
:D :D :D :D :D :D
Tim
timmoore46
Tue Feb 26, 2013 9:12 am
$logFile
The upper case F
does that have significance ?
what would happen if it was :-
$logfile
I'm just paranoid about anything as unforgiving as assembler or BASH.
:D :D :D
Tim
DBryant
Tue Feb 26, 2013 10:00 am
None at all. There are several 'standards', styles might be a better term for naming variables, where an effort is made to improve legibility, given that including spaces is not really a preferred option.
One is two capitalize words (after the first one) and hence logFile. Another would be to insert underscores, so this would be log_file. Another one would be to do nothing, as in logfile.
Just be consistent throughout your script, don't expect logfile and logFile to be interchangeable, they are not. And developing a style is good because you may want to slice your script across several files, such that functions can be used in other projects. Then a definite style will benefit your development.
All are valid, depends on ones attitude to this things. Once a script gets big, any slight advantage becomes very useful. Even using logfile instead of just 'l' is an improvement, simply because you can use your editor to search out logfile instances better than l instances.
Shells tend to read variable names up until the first invalid character so another thing you might come across is ${logFile} i.e delimited by {}. Tends to be used when you're printing plurals and you want that additional s; so "${logFile}s" works as you might intend but NOT $logFiles which is rarely correct. And yes, there are other ways of handling this scenario.
Not sure that I'd agree that bash is particularly unforgiving.
Since bash is text based, and our eye/brain is well tuned to processing text, we assume that anything we write is perfectly legible. By legible I mean the mechanics, of space, the usage of capitaliz/sation, sleping, apostrophe's and so on, which we can parse and interpret in our brains to get the underlying sense. And then we still get it wrong on occasion. We get into the habit that these things are unimportant, but they are, and particularly to command line shells like bash, csh and the rest of them. 'Particularly' because they really need a pre-processor to sanitize the text before its thrown at the shell interpreter, exactly what a compiler might do in part in the wonderful world of Java for example.
Nuff said :!:
timmoore46
Wed Feb 27, 2013 6:51 am
code was:-
and the hope was all the screen output would wind up being added to a file.
the output that actually is out put to the screen is:-
quote
root@raspberrypi:~# ./test_002
Wed Feb 27 06:43:28 UTC 2013
y is :-
1
z is :-
0
Wed Feb 27 06:43:34 UTC 2013
y is :-
1
z is :-
0
Wed Feb 27 06:43:40 UTC 2013
y is :-
1
z is :-
0
end quote
_________
using ls and nano I can't find any file with that in it.
so what is the name of the file I'm looking for and where is it (which directory) ?
I am operating in the root directory because it makes chmod very easy to use.
( I'll agree with you on BASH does give error messages but I'd hate to make a mistake using DD)
:D :D :D
Tim
DBryant
Wed Feb 27, 2013 8:06 am
logfile and logFile!!!! To quote my previous response
Your first lines have to be
logFile="control_004.log"
where I've highlighted the two parts that must agree.
As it stands $logFile is empty and for tee the file argument is optional (see the man page http://unixhelp.ed.ac.uk/CGI/man-cgi?tee where is enclosed in [] (as in [FILE]) meaning optional). So in your code tee accepts stdin, write to stdout, and nothing else; no file with no name, zilch, zippo.
So change the line
 logfile="control_004.log" => [b]logFile[/b]="control_004.log"
I think you malign dd, it comes down to accuracy of the user. It expects a valid src and a valid destination, switch them around and all hell breaks lose. Driving on the right (in the UK) is equally catastrophic. As in most cases what we want is "do what I mean, not what I say" but shells, and computers in general, don't work like that
timmoore46
Wed Feb 27, 2013 8:31 am
code:-
logfile="control_004.log" => logFile="control_004.log"
yields
./test_002: 13: ./test_002: cannot create logFile=control_004.log: Directory nonexistent
would be be easier to follow if the name was changed of 'logFile' to 'example_001' ?
have I made an idiot typo ?
Tim
DBryant
Wed Feb 27, 2013 8:48 am
The => means 'becomes'!
Your code should read
timmoore46
Wed Feb 27, 2013 8:56 am
Many thanks, I'll try that.
a small mystery
nano control_004.log
yields
Mon Feb 25 18:08:38 UTC 2013
Mon Feb 25 18:08:44 UTC 2013
Mon Feb 25 18:08:51 UTC 2013
Mon Feb 25 18:08:57 UTC 2013
Mon Feb 25 18:09:03 UTC 2013
Mon Feb 25 18:09:09 UTC 2013
Mon Feb 25 18:13:15 UTC 2013
Mon Feb 25 18:13:21 UTC 2013
Mon Feb 25 18:13:27 UTC 2013
____
and
cat control_004.log
yields
Wed Feb 27 08:47:59 UTC 2013
Wed Feb 27 08:48:05 UTC 2013
____
Many many thanks for your support !
:D :D :D :D :D :D :D
Tim
timmoore46
Wed Feb 27, 2013 9:24 am
root@raspberrypi:~# cat control_004.log
Wed Feb 27 09:04:22 UTC 2013
Wed Feb 27 09:04:28 UTC 2013
the rest of it is missing.
viz:-
start quote
y is :-
1
z is :-
0
end quote
:D :D
Tim
DBryant
Wed Feb 27, 2013 9:26 am
You are looking at 2 different files I would guess.
What directories are you invoking the nano and cat commands from?
Why not just tidy up all log files and start again? The script should be run as the pi user, within pi's filesystem and so on. Running within the root directory just because of perms is not a good habit to get into.
To find all files then
sudo find / -name control_004.log
will scan the whole file system. Its run as the superuser so it can wander over the whole of the filesystem without any permissions issue. The / is the root os the filesystem, so the command will recursively span the entire directory tree.
You can rm then all with:
sudo find / -name control_004.log -exec rm {} \;
You are then in a position to start again, now your code is doing vaguely the right thing.
In the above commands you could replace the / with /home/pi, assuming you were disciplined to only work within the pi accounts filesystem and only run your script as the pi user. The commands are then (we no longer need the sudo):
find /home/pi -name control_004.log
find /home/pi -name control_004.log -exec rm {} \;
As a final comment, if it were me, then I'd construct logFile to include the directory location too as follows
logDir="/home/pi/logs"
logName="control_004.log"
logFile=${logDir}/${logName}
this gives great ease to modify the directory and the name of log file. In the future, you might then decide to make logDir depend on the date, so you have logs stored in a daily (named) folder. This can be overkill etc. but in 15 years time when changes are to be made, it all becomes a breeze.
