droidus
shutdown command
Wed Feb 20, 2013 4:07 am
Hello everybody:
When I try to shutdown my Raspberry Pi with the command "sudo shutdown now", it gets to:
"Give root password for maintenance
(or type Control-D to continue):"
So I type in my password for the root account. then it comes up with the root account prompt. So I type the command in again. I then comes up with the prompt again. How do I properly shut it down?
FidelGVelasquez
Re: shutdown command
Wed Feb 20, 2013 4:13 am
"sudo poweroff" shuts down; "sudo reboot" reboots
tonyhughes
Wed Feb 20, 2013 4:37 am
sudo shutdown -h now
Jessie
Wed Feb 20, 2013 5:41 am
I generally just put in "sudo halt" since you have to pull the cord to actually shutdown a Pi. Sometimes I forget it's attached to a USB port on my TV so my family will turn it off and on a couple times a day without shutting down. So far no damage from this.
alexeames
Wed Feb 20, 2013 8:19 am
Jessie wrote:I generally just put in "sudo halt" since you have to pull the cord to actually shutdown a Pi. Sometimes I forget it's attached to a USB port on my TV so my family will turn it off and on a couple times a day without shutting down. So far no damage from this.
Seconded.
sudo halt
seems to be the lowest number of keystrokes to do the job. :) I've found that lower quality SD cards tend to corrupt if you pull the plug, but better ones cope OK.
Alex Eames RasPi.TV, RasP.iO
