flowersrj
interfaces configuration problem
Thu Feb 14, 2013 3:25 am
My Interfaces file is shown below. My problem is that I can't access wifi after re-booting unless the ethernet is plugged in beforehand. Can anyone tell me what I am doing wrong? If the ethernet cable is plugged in I want to use that. If cable not plugged in I want it to use the wifi IP. With both plugged in on boot, I can ping both IPs.
Thanks, Rich
auto lo
auto lo inet loopback
allow-hotplug eth0
iface eth0 inet static
address 192.168.1.11
netmask 255.255.255.0
gateway 192.168.1.1
broadcast 192.168.1.255
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.1.12
gateway 192.168.1.1
wpa-conf /etc/wpa.conf
totoharibo
Re: interfaces configuration problem
Thu Feb 14, 2013 9:41 am
I tried the same but it never works.
I think it is a problem of default route : which interface for default route ?
Not able to find a solution at this level.
A possible solution is to test activity of links but not found something about.
PS1981
Thu Feb 14, 2013 9:43 am
So I actually don't know what I'm talking about, but could it be that you need an "auto wlan0" in there somewhere?
flowersrj
Sun Feb 17, 2013 3:15 am
Don't know but th ethernet part works fine. It I reboot with cable out then plug it in later, the interface comes up fine and I can access PI via its IP.
Rich
