ghans
Re: New, and kind of lost
Mon Aug 04, 2014 8:04 am
The use of sudo has been a bit excessive in my old instructions ,
here are corrected ones :
How to get pianobar working on Raspbian
UPDATED (Oct 2014)
Drop to a terminal (you can use "LXTerminal") and enter following commands ,
pressing RETURN after each line :
cd ~
sudo apt-get update
sudo apt-get purge pianobar
sudo apt-get install git pkg-config libevent-pthreads-2.0-5 libao-dev libgnutls28-dev libmad0-dev libfaad-dev libjson0-dev libgcrypt11-dev
git clone git://www.github.com/PromyLOPh/pianobar.git
cd pianobar
make clean
make
sudo make install
nano ~/.config/pianobar/config
add the line
tls_fingerprint = 2D0AFDAFA16F4B5C0A43F3CB1D4752F9535507C0
Save (CTRL-O) and exit (CTRL-X) .
Now entering
pianobar
should start pianobar.
In case of problems , report back with the exact error messages,
and the command you issued just before that (use copy-paste).
ghans
fsoguy
Sat Oct 18, 2014 9:06 pm
ghans wrote:Because you have asked so nicely :
sudo apt-get update
sudo apt-get install git pkg-config libevent-pthreads-2.0-5 libao-dev gnutls-dev libmad0-dev libfaad-dev libjson0-dev
sudo git clone git://github.com/prattmic/pianobar.git
cd pianobar
sudo make clean && make && make install
ghans
Worked for me too. Many thanks!! I spent a couple hours trying to do apt-get install and another git hub directory, neither of which worked.
UPDATE
I had an occasional error while using this build. I would get this: Cannot access audio file: Unknown HTTP status code, and the song would freeze with a second or two left on the counter.
I just finished installing from source using: https://github.com/PromyLOPh/pianobar
The error is discussed and apparently fixed in this version of pianobar from PromyLOPh. The build date when running pianobar is quite recent: Welcome to pianobar (2014.09.28-dev)
Hoping for the best on this. Before it would hang and I'd have to get back to the station list, or restart pianobar completely.
dunuplost
Thu Nov 27, 2014 4:40 pm
Hey folks I ran into the same as everyone on pianobar. I needed to rebuild but ran into the build error.
[email protected] ~/pianobar $ make
Package libavcodec was not found in the pkg-config search path.
Perhaps you should add the directory containing `libavcodec.pc'
to the PKG_CONFIG_PATH environment variable
No package 'libavcodec' found
Package libavformat was not found in the pkg-config search path.
Perhaps you should add the directory containing `libavformat.pc'
No package 'libavformat' found
Package libavutil was not found in the pkg-config search path.
Perhaps you should add the directory containing `libavutil.pc'
No package 'libavutil' found
Package libavfilter was not found in the pkg-config search path.
Perhaps you should add the directory containing `libavfilter.pc'
No package 'libavfilter' found
CC src/main.c
In file included from src/player.h:27:0,
from src/main.h:30,
from src/main.c:57:
src/config.h:12:33: fatal error: libavfilter/version.h: No such file or directory
compilation terminated.
Makefile:127: recipe for target 'src/main.o' failed
make: *** [src/main.o] Error 1
So I found this link:
http://www.lanmaster53.com/2014/05/rasp ... -pianobar/
After building the FFmpeg my build for piano bar went just fine.
I am sure there is a build of FFmpeg out there I just kicked off the build before a sleep so it worked for me...
Who is online
Users browsing this forum: No registered users and 27 guests
