Re: industrial case
Posted: Wed Feb 22, 2012 9:27 am
by Szpliter
Hello everyone.
I am interested in the RPI adjustment to industrial development. I'm looking for solutions for DIN rail mounting with class IP66 or IP65.
Can anyone encountered any solution for RPi ?
Szpliter
Re: industrial case
Posted: Wed Feb 22, 2012 9:45 pm
by slacer
you can go to http://www.conrad.com and search for "DIN rail case" and you should find some nice solutions.
Re: industrial case
Posted: Thu Feb 23, 2012 9:10 am
by RaTTuS
as the RPI *yet* does not have any mounting holes it will be a bit challenging to keep in so YMMV
Re: industrial case
Posted: Thu Feb 23, 2012 10:34 am
by redman684
If you just want the pi inside a box without any connections to the outside, things are easy. But that's probably not what you want.
Which connectors do you wish to use, how are you going to power it? Have you thought about that?
The conntectors on the pi will probably not match the IP65 requirements at all, I even expect the composite video connector to have a 3mm hole straight through. The positions of the connectors will make rail mounting difficult too.
Re: industrial case
Posted: Thu Feb 23, 2012 11:40 am
by jamesh
No, connectors have no IP rating,. You would need to use flying leads to IP rated connectors on the box.
Re: industrial case
Posted: Thu Feb 23, 2012 12:21 pm
by slacer
http://dmkenr5gtnd8f.cloudfron.....front1.jpg
This image shows at least two mounting holes on the left side of the raspberry logo near label c5 and s2
Re: industrial case
Posted: Thu Feb 23, 2012 12:50 pm
by RaTTuS
http://elinux.org/images/thumb.....iFront.jpg
they are not mounting holes really
Re: industrial case
Posted: Thu Feb 23, 2012 1:40 pm
by davidgoodenough
I would suspect those holes are there to hold the SD card socket.
Re: industrial case
Posted: Thu Feb 23, 2012 1:53 pm
by caulktel
Back in my Ham radio building days we used to use thin nylon channel and attach it to the sides of the enclosure then slide the circuit board in to the channels thus not needing any mounting holes. The only problem is, the enclosure needs to be the exact width. We used to make our own boxes too so that wasn't a problem. If I ever get the Rasp in my grubby little hands, I will figure out some king of enclosure.
Re: industrial case
by caulktel
Back in my Ham radio building days we used to use thin nylon channel and attach it to the sides of the enclosure then slide the circuit board in to the channels thus not needing any mounting holes. The only problem is, the enclosure needs to be the exact width. We used to make our own boxes too so that wasn't a problem. If I ever get the Rasp in my grubby little hands, I will figure out some kind of enclosure.
