Re: Gaming
Would a Rasppi run TF2???????..........
Re: Gaming
if we think about the "raw" power of the gpu: "maybe"
if we think about the fact that there are no ports of TF2 for ARM6 and Valve is surely not porting it: NO
Re: Gaming
The Raspberry Pi WILL NOT run:
Any PC game
Any Playstation game
Any XBox game
Any Wii game
A very few PC games do run, but it"s a handful of older ones. Quake3, Doom, sort-of-thing. Then a few DOS-based games can be made to work. UFO for example. But even those don't work out of the box, they require a fair amount of knowledge to set-up, and they are very much the exception to the rule.
The rule is: Even if it says Linux on the game"s box, it still wont work.
Any PC game
Any XBox game
Any Wii game
Re: Gaming
Hey - Quake3's nothing to sniff at Ah... flashbacks to my student days playing capture the flag
Re: Gaming
Pygame should run happily of course, so if you want to play something the obvious solution will be to write it
- Contact: Website
Re: Gaming
Although i won"t be using the PI for gaming, I have Doom and Doom 2 installed on my laptop – Nothing beat some good old FPS action
Re: Gaming
I think the thing to consider is that once the raspi is established there will be more than enough enjoyable games, and game clones to keep even the most harded gamer going for a while. also games that will take full advantage of the monster gpu. that is what I'm looking forward too.
Regards Gee
Regards Gee
Gee The Rabid Inventor
Re: Gaming
Mmm.
Open Source game are the best candidates to run on R-Pi, cause they can be ported. (theorycally). There will be some issues with video driver compatability and run mode (X, framebuffer, opengl-es), but i think people will furnish a r-pi game station image sooner or later.
BTW. Dowlload debian r-pi image, setup your qemu and install prboom. At least you can play doom in console mode
Re: Gaming
So could someone upload a copy of Quake 3 for the Rasppi and give me a link because I would be highly appreciative.
- liz
- Raspberry Pi Foundation Employee & Forum Moderator
- Contact: Website
Re: Gaming
We may well be making that download available, but it'll probably be after launch some time.
Director of Communications, Raspberry Pi
Re: Gaming
How long after the launch,where would it be available from and would you have to pay for it.
Re: Gaming
I'm not in the foundation but I'd guess:
However long it takes, the foundation page or somewhere else pointed at from the foundation page or forums, no it is open source so you won't have to pay.
Re: Gaming
mole125 said:
Only the engine is open source, not the game data. You'll have to get that from a commercial copy of the game or use substitute data from projects like OpenArena.
- Raspberry Pi Engineer & Forum Moderator
Re: Gaming
Actually I put Quake3 up last week.
https://github.com/raspberrypi/quake3
Should be buildable with libs from the debian rootfs.
There's also a suitable toolchain in:
https://github.com/raspberrypi/tools
(although any arm one should do).
You need the pk3 files and CD key from a real Quake 3 CD.
In theory this should work with openarena pk3 files, but it will need a merge with a newer version of the quake3 tree.
As it is, the pk3 files are rejected, and the code that loads them has been modified since we branched.
If anyone fancies trying the merge, feel free.
Re: Gaming
Anyone remember Introversion's Linux versions of Defcon, Uplink, and Darwinia from a few years back? Although not 'the feel good game of the year', Defcon was a fun one for me. I kept flashbacking to when I saw Wargames in a theater so long ago...
Re: Gaming
You will definetley be able to play awesome games on a emulator.
I found that mupen 64 will work so yeah ZELDA
ZELDA ZELDA ZELDA ZELDA ZELDA ZELDA ZELDA!!!!
Re: Gaming
Wow! fully ported to gles?
Re: Gaming
Yep. Runs very well.
Re: Gaming
Not necessarily true. I think the Pi might have enough raw power to run a PS1 emulator, if there was one ported for ARM.
Re: Gaming
Yep, the ps1 has pretty low specs and you can emulate it on quite a low spec machine. I'm more interested in older systems.
Also, we should perchance keep the number of tm "emulator" topics low on the official site. I'd hate for the foundation to get flak for "supporting" emulation.
Re: Gaming
I doubt we will see PS1 emulation.
There is nothing wrong with emulation. It is the theives that play ROMs they do not own that is the issue. I don't feel like getting my SNES out of the garrage to play Zelda or FF games and why should I when I can fire up an emulator on the PC. If someone ever got PS1 emulation working there is absolutly no reason why the games couldn't be played directly off the disc. I'm no foundation member but I think it is perfectly fine for them to support emulation projects as long as they do not support game theft. That will be their call to make in the end, but IMO there will be many R-Pis with the sole reason to emulate classics.
Re: Gaming
Theft is the taking of property with the intent to permanently deprive the owner of it. I do not think that emulation projects could support or encourage that.
Perhaps you meant unauthorized copying.
- Contact: Website
Re: Gaming
Goggles2114 said:
http://www.zeldaclassic.com/
Any chance of the linux port working on arm?
I wouldn't put money on it. I don't see source on there, so a port (likely a rebuild, and little more) would have to be done by them. You'll have to talk to them (unless the source is around and I just missed it).
Re: Gaming
Unlikely. The Linux version will be for x86.
There's a DOS version there, so it should work under DOSBOX. No guarantee on speed though; if they are expecting 2005 hardware, it's likely to be snail-like.
