lusil
Re: Where to buy small solar panels?
Mon Feb 20, 2012 12:55 am
The fan I am insterested in requires a 20 watt solar panel. The fan runs directly off this panel and as the sun increases the fan increases speed. It would be hooked up to a thermostat so that it wouldn't start running untill the greenhouse is a certain temperature. The fan is .7 amps when 12vdc is used.
A light would be like 130 watts 2.1 amps 12vdc
This is just a normal light, so I can work in the evening. It is not for the plants. I am sure I can find suitable lighting elsewhere because the greenhouse place only offers this light.
I would like the battery to store power for the lights and maybe something else like a small fan.
I understand that the solar panels are NOT cheap however I just think that buying them from a company that specializes in solar products, rather than greenhouse products, would be smarter. Then I can buy the fan and other special stuff from the greenhouse place. I really only want a simple setup and right now my main concern is ventilation so starting with the simple battery-less system is fine with me. I can always upgrade later. Ventilation is a necessity as other things, like lighting, are not right now.
I have always wanted a greenhouse however I don't want to use more power for it. I am trying to build a greenhouse so I can get rid of some of my light stands and save energy.
I think that also building the greenhouse with a smaller projection from the house would also save money (less air space to heat by the sun)
I haven't fully determined what to do for winter heating yet though. We use a pellot stove mainly and will be buying a second one this summer hopefully. Our current one doesn't have a battery backup. I think the heating situation really depends on how much it does actually cost to heat. The "greenhouse heating cost" calculators don't predict it will cost too much to heat but I really don't believe them that much.
Lynbarn
Mon Feb 20, 2012 1:00 am
I'm not sure why you're posting here, unless you want to computer-control your fan, but have you tried Googling "cheap solar panels"?
That should give you 27,900 or so possible leads…
gimliflea
Mon Feb 20, 2012 10:44 am
Maybe he's growing raspberries for the pie in his green house
Vindicator
Mon Feb 20, 2012 5:35 pm
I am thinking this poster is on the wrong website altogether from their post. LMAO if not I wonder if they would clarify.
If you are more worried about ,spelling, punctuation or grammar you have probably already missed the point so please just move on.
timn
Mon Feb 20, 2012 6:28 pm
For ventilation you need a solar-powered window opener. Go to Amazon and seach for: greenhouse window opener.
