bass0324
Wifi Direct Enabled
Tue Jan 29, 2013 2:49 pm
For anyone else who is wishing to use WiFi-Direct with the Raspberry Pi to connect with Android devices, I have finally achieved this. At first I tried to use any WiFi USB Dongle and recompile wpa_supplicant with p2p enabled but this didn't work. Then I found this guide: http://dishingtech.blogspot.com/2012/01 ... guide.html This guide showed how to enable p2p with the RTL8192 chipset for Realtek.
So went to Amazon and ordered this dongle: http://www.amazon.com/gp/product/B004HY ... 00_s00_i00
Following the guide, p2p worked correctly first try, and no need to recompile a new wpa_supplicant with p2p enabled. Hopefully others find this helpful since I would have if seen this 3 months ago.
CaffeinatedAndroid
Re: Wifi Direct Enabled
Thu Jan 31, 2013 5:28 pm
That's fantastic, just what I needed!
Will give this a go and hopefully see if it works.
oritpro
Sun Mar 17, 2013 6:55 pm
I recently spent some {quality} time trying to get P2P working on an Edimax EW-7811Un, it also uses the rtl8192cu chip.
Using kernel drivers under 3.6.11+ and with P2P enabled via iwpriv wlanXX p2p_set enable=1, the Pi can see a WiFi Direct enabled Android device and vice versa, but they cannot connect. I tried two Android devices, an SGS2 and a Nexus7 which do connect to each other fine via P2P.
A little research turned up a developer thread dated March 7th 2013 that included Larry Finger, one of the RTL driver developers. It turns out that P2P "is not yet implemented in rtl8192cu" according to Larry.
Here's a link to that thread: http://www.spinics.net/lists/linux-wire ... 04531.html
It would appear that we might have to wait until kernel v3.10 or later for full P2P support on RTL. However, in the interim, if somebody has found (or finds) a way to get P2P working on Raspberry Pi please post a how-to.
sk8ergeek
Sat May 25, 2013 2:04 pm
I've used RTL8192 chipset, TP-Link WN725N and Rapsberry Pi can ping android phone after connected both of them.
This is for the result here
[modded by mod to remove the spammy urlshortener]
annamol.alex
Thu Feb 06, 2014 5:43 am
I have a rasp model b running raspbian and kernel 3.9.11, edimax ew7811un , a samsung galaxy s3 and a legacy 802.11 device . I need to establish a wifi direct connection with these. The phone can be made the group owner and legacy devices detects the same but fails to connect .
I need to know whether the rasp can be made the group owner in the wifi direct group formation .. it fails at the provision discovery stage with the realtek user interface. I don't know how to debug the same...
Regards
annamol
edwin6938
Tue Apr 29, 2014 4:36 pm
I read everything, but i'm completly lost... I have a TP-LINK Dongle for Wifi (with a CD installation for drivers)...And i have no idea how to do my wifi works....
I plugged the dongle and then my computer is connected in SSH to my RPi (using Raspbian).
At this point i don't know what to do. Can you, please, help me?
BMS Doug
Wed Apr 30, 2014 10:56 am
edwin6938 wrote:Hi,
I got my WIFI dongle last night, setting it up was very easy but I did use a HDTV as a monitor (as it seemed the easiest way when I read this guide).
I just started the GUI (startx) and used the wifi setup. there is a description (in the guide I linked) telling you how to edit the script but if you can access the GUI it is very easy.
Edit: oops, probably not relevant if you want wifi direct , sorry.
Doug.
edwin6938
Wed Apr 30, 2014 5:39 pm
Actually, i have :
- Wifi Dongle : TP-Link TL-WN725N version 2
- Linux raspberrypi 3.10.25+
I tried every tutorial and nothing works. I saw that i need to upload the driver rtl8188eu. So i did it here:
https://dl.dropboxusercontent.com/u/80256631/8188eu-201xyyzz.tar.gz
Then i did :
tar xvf rtl8188eu-20131223.tar.gz
sudo depmod -a
sudo modprobe 8188eu
And then i have an error : "ERROR: could not insert '8188eu': Exec format error...
Please help!!! I tried a lot of tutorial to find good drivers!
MrEngman
Wed Apr 30, 2014 8:00 pm
edwin6938 wrote:Actually, i have :
Then i did :
sudo depmod -a
What does command uname -a report?
MrEngman
edwin6938
Fri May 02, 2014 11:26 am
I succeed in installing, but i still don't have wifi... When i do :
- ifconfig : I have wlan0 (I didn't before)
- iwlist scanning, i have all the good networks
But i can't connect WIFI... When i do ifconfig, i have :
wlan0 Link encap:Ethernet ....
Is it normal to have "Ethernet"? Maybe i wrote wrong in /etc/network/interfaces?
I have :
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
auto wlan0
iface wlan0 inet dhcp
wpa-ssid "SSID"
wpa-psk "PSK"
MadMel
Tue Jul 01, 2014 8:19 am
Hey guys
I have just started with using the raspberry Pi for a project for uni and need some help. I am designing a remote controlled robot using the RPi and the arduino (like the ones on youtube) and i have got it to work but the problem is that i need to setup WIFi direct so i can use it outdoors. I am using the TP-Link TL-WN721N wireless USB that already as a built-in driver in raspbian. Can someone please give me instruction for a noob to follow as i am really stuck on this and it is the last thing i need to complete my project.
Cheers
bass0324
Wed Jul 30, 2014 2:39 am
All,
Sorry for not getting back to you as quickly as I would have liked. Here are the commands I used in order to test on a brand new raspbian build:
sudo apt-get update && sudo apt-get upgrade && sudo apt-get install firmware-realtek
mkdir ~/Wifi_Direct
cd ~/Wifi_Direct
git clone https://github.com/bass0324/rtl8192cu.git
cd rtl8192cu/WiFi_Direct_User_Interface/
chmod 777 ./install.sh
./install.sh
sudo ./P2P_UI wlan0
This then brings up a GUI in which these commands were run in order to connect to another device:
e
1
a
m
- Select the mac address of the device you wish to connect to (should be named same as android device)
p
1
On the wifi direct device (android in my case) type in the password
12345670
Once this is complete, you should now have a completed Wifi Direct interface between your Android device and the Raspberry Pi. In order to implement this in other ways, there is C code in the same folder the ./P2P_UI code is run which contains all of the commands used by the GUI in order to create the connection. These commands can be manipulated in other code in order to do what you need them to do. Let me know if there is any other questions you guys may have.
Regards,
John
bantammenace2012
Thu Dec 11, 2014 5:48 pm
I've just got hold of the Broadcom Wifi Adapter. It's advertised as supporting Infrastructure mode, Wi-Fi Direct and soft-AP mode.
Does anyone know how to configure it on my RPi to work in Wi-Fi Direct mode ?
I want to use it to stream video to my Nexus 5 initially but ultimately to an RPi attached to a HDMIPi display.
I want to do this to avoid the hassle of setting up IP addresses etc.
bass0324
Fri Jan 09, 2015 1:24 pm
bantammenace2012 wrote:I've just got hold of the Broadcom Wifi Adapter. It's advertised as supporting Infrastructure mode, Wi-Fi Direct and soft-AP mode.
I only know that the rtl8192cu chipset worked easily without creating any new drivers. You can test your adapter if any of the iwpriv commands work, those were the p2p commands needed in the code to make Wifi direct work. If it doesn't work with that command, I don't think I'll be able to help you with that adapter.
Regards,
John
kylehsu
Wed Feb 04, 2015 2:40 am
hi
i try to connect raspberry pi with another one.
but why GO's screen stop at the command "start hostapd"
keerthipkumar
Wed Feb 04, 2015 9:46 am
hi
i am starting to use raspberry pi. I need to control it using my smart phone.i am using Edimax 150 mbps dongle.i need to install wifi direct in my pi.please tell me how to install it.should i need any other driver or software to install.Also what is 'dev'.please do reply.
dcdan
Sat Mar 14, 2015 3:54 pm
edwin6938 wrote:Hi,
I have :
auto lo
allow-hotplug wlan0
auto wlan0
wpa-ssid "SSID"
wpa-psk "PSK"
Did you succeed? I'm starting just like you did. Would you recommend the driver source you used? That is my first step i guess?
Naveen Kumar S
Mon Apr 06, 2015 7:09 am
I tried to enable the p2p using the following code but it didnt work can anyone give a solution how to enable wifi direct on the raspbian.
[email protected] ~ $ iwpriv wlan0 p2p_set enable=1
wlan0     no private ioctls.
bendavis
Mon Jul 13, 2015 8:39 pm
I bought the wifi adapter you suggested, but the driver loaded (r8712u) does not seem to support p2p. What driver are you using for this?
krb
Sun Oct 04, 2015 5:53 am
Hello John,
Thanks for your instructions. I followed them and got the WiFi_Direct_User_Interface installed. At the end of the build it prompted "WiFi_Direct_User_Interface install complete!!!!!!!". I run ./P2P_UI wlan0 and the UI shows up. But when I enter the command e, 1. It gives me an error:
Invalid command : p2p_get
I am not sure what I am missing?
Your help would be greatly appreciated.
Thanks,
KRB
bass0324
Mon Oct 12, 2015 6:27 pm
krb wrote:Hello John,
Thanks,
KRB
What is the usb dongle you are using?
John
bass0324
Mon Oct 12, 2015 6:30 pm
bendavis wrote:I bought the wifi adapter you suggested, but the driver loaded (r8712u) does not seem to support p2p. What driver are you using for this?
I used the standard Linux firmware for the Realtek devices, as seen by my install of it.
John
bass0324
Mon Oct 12, 2015 8:12 pm
Naveen Kumar S wrote:I tried to enable the p2p using the following code but it didnt work can anyone give a solution how to enable wifi direct on the raspbian.
Sorry for the late post. No private ioctls typically means that the devices doesn't support the iwpriv commands. Had the same issue with a dongle that didn't have the Realtek device Ispecified. I didn't try many other devices since I didn't want to spend a lot, but I know this once works.
krb
Tue Oct 13, 2015 2:53 am
I used the dongle that was suggested in this post: http://www.amazon.com/gp/product/B004HY ... 00_s00_i00
GMYLE Wireless N/G 802.11n/g USB WiFi WLAN Network Adapter (Realtek RTL8191SU) with high Gain 5dBi Antenna Up to 300Mbps
I also installed the standard realtek firmware.
Thanks for your help,
krb
JangYoungwoo
Wifi Direct Enabled
Sun Nov 29, 2015 12:22 pm
Hi I'm Jang in South Korea
I did connect android to rpi with wifi direct but I can't do it..
I did search device rpi on android, but android was can't search rpi device
what happen this problem?
help me please
I've used RTL8188eu driver, RTL8192cu chipset, TP-Link WN725N and Rapsberry Pi
