cdesseno
Re: Root filesystem available to download
Fri Feb 17, 2012 11:17 pm
I just tested with this and it worked ok (/dev/sdb is the the SD card, please be carefull)!
sudo dd if=debian6-17-02-2012.img of=/dev/sdb bs=1M
jojopi
Fri Feb 17, 2012 11:22 pm
The password for user "pi" is "suse".  Since I needed to know that, am I booting it wrong?
liz
Fri Feb 17, 2012 11:31 pm
No, actually; Eben's just editing the download page now to reflect that.
aclearn
Fri Feb 17, 2012 11:33 pm
> ATM here the torrent  is ~60-140KiB/s | ~5-30KiB/s : ~40 of 60 peers
I had other torrents running, after stopping them it is now ~250KiB/s+ down. I don't think I'll bother with the above
mjdon
Fri Feb 17, 2012 11:42 pm
I also tried to run this file with qemu. I installed qemu et kvm-pxe on my ubuntu tried:
qemu -m 256 -sd debian6-17-02-2012.img
but it only tells me:
Booting from Hard Disk...
but nothing moves. I suppose I have to specify explicitly which architecture I'm trying to run. So if anyone knows which command we should use to run this image file with qemu, please tell us.
teh_orph
Sat Feb 18, 2012 12:17 am
Hi Liz,
I'm still downloading so can't check - can I ask: does this come with the GPU blobs etc required to boot the machine or will they come in later downloads?
Cheers!
liamfraser280
Sat Feb 18, 2012 12:19 am
Hi tech_orph.
This image is ready to go on the Raspberry Pi. It can be written straight to an SD card. So yeah the blobs and fat32 partition are in there too!
Cheers,
Liam.
ukscone
Sat Feb 18, 2012 12:33 am
some interesting stuff in /opt
and the files in the fat partition.[raspberry@localhost debrootfs]$ ls -al
total 28078
drwxr-xr-x. 2 root root 2048 Dec 31 1969 .
drwxr-xr-x. 8 root root 4096 Feb 17 16:52 ..
-rwxr-xr-x. 1 root root 2001244 Feb 17 12:02 arm128_start.elf
-rwxr-xr-x. 1 root root 2001244 Feb 17 12:02 arm192_start.elf
-rwxr-xr-x. 1 root root 2001244 Feb 17 12:02 arm224_start.elf
-rwxr-xr-x. 1 root root 16528 Feb 13 18:53 bootcode.bin
-rwxr-xr-x. 1 root root 141 Feb 14 18:38 cmdline_testmode.txt
-rwxr-xr-x. 1 root root 127 Feb 14 18:52 cmdline.txt
-rwxr-xr-x. 1 root root 16412020 Feb 14 18:47 kernel_emergency.img
-rwxr-xr-x. 1 root root 3990020 Feb 13 18:53 kernel.img
-rwxr-xr-x. 1 root root 314691 Feb 13 18:53 loader.bin
-rwxr-xr-x. 1 root root 2001244 Feb 17 12:02 start.elf
Tee
Sat Feb 18, 2012 12:55 am
Public HTTP Mirror available at - http://www.raspberrypidownload.co.uk
All future releases for the Pi will be available at the above link
teh_orph
Sat Feb 18, 2012 12:57 am
Cheers Liam.
The torrent has finished now (quicker than expect) and I see there's that partition at the front with the extra files.
Good work guys...
liamfraser280
Sat Feb 18, 2012 12:59 am
Thats thanks to the army of ~900 and climbing seeders we have! Cheers all !
errikos
Sat Feb 18, 2012 2:04 am
I don't know if this is the right place to ask, but is it possible to have a smaller image for the bootloader only to put in a small SD card, and keep the main filesystem to an external USB hard disk drive? For most multimedia functions, I don't think that just the SD card will be adequate...
Thanks!
riggsre
Sat Feb 18, 2012 2:44 am
I was able to DL using torrent and I am seeding.
You guys are way ahead of me using Linux. I hope this helps other beginners.
I loaded Fedora 14 on a Vitrual machine. I put the unzipped img file in Documents, opened a terminal window typed cd Documents (enter) then typed su (enter) and put in my password (you won't see the password or any "*" or anything) and press enter again. Then type:
Press enter.
(credit Carlos on February 17, 2012 at 11:08 pm)
I had to wait about 5 minutes (maybe longer) before the cursor came back. You will have to eject the SD card and reinsert it and it should look something like this:
I don't know yet if it will work. No way to test it.
rr
crossfireprod
Sat Feb 18, 2012 3:35 am
Another HTTP Mirror:
http://raspi.crossfireproductions.org/
(Datacenter located in Ashburn, VA)
RasPi Staff:
Apparently there are plenty of us looking to donate bandwidth, perhaps an official mirror distribution system is in order?
ReCreate
Sat Feb 18, 2012 4:06 am
http://recat.pccloud9.me/raspi/
Hopped on the mirror bandwagon.. Because why not. I have unlimited bandwidth on this host. This server appears to be located in Brea, California, US
MoonTEC
Sat Feb 18, 2012 4:18 am
Thanks!
You can do it Yourself. From downloaded image write only first (boot) partition to SD. Create/copy second(root) and swap partitions to external USD hard disk drive. Change path in SD card file cmdline.txt, where root=/dev/mmcblk0p2 to Yours external disk root partition, in most cases root=/dev/sda1. Edit /etc/fstab in root partition changing swap partition path.
Not all files in boot partition are necessary, so SD card size can be 16MB.
peterpi
Sat Feb 18, 2012 7:29 am
Today I discovered that my Linode virtual server can burn through its 90GB monthly transfer cap in, err, about 90 minutes!  Oops.  It's not something I ever think about on my unlimited (but slow) home connection.
liamfraser280
Sat Feb 18, 2012 8:37 am
Sorry to hear about that peter! Thanks for helping out though
RaTTuS
Contact: Twitter YouTube
Sat Feb 18, 2012 9:34 am
I'll be leaving the torrent up for a few months ;-p
Covfefe
PhilS
Sat Feb 18, 2012 11:40 am
Seeding with a 100Mbps upload
liamfraser280
Sat Feb 18, 2012 11:44 am
Thanks all! 1653 leechers & 1523 seeders!
Shows the amazing power of the community. Lets hope we can do the same when the fedora 14 image comes out in a couple of days!
We're all really impressed!
Liam.
daVirus
Contact: ICQ
Sat Feb 18, 2012 12:11 pm
also seeding on my root box
Bandwith: 100 MBit (max)
hope it helps a lil bit
PhilS
Sat Feb 18, 2012 1:05 pm
Liam.
I'll be seeding!
liamfraser280
Sat Feb 18, 2012 1:52 pm
Hi all,
You're all doing a great job with the mirrors. I'd just like to point out that you should add your mirror to the list on the wiki if you haven't already.
http://elinux.org/RPi_Communit.....ad_Mirrors
Cheers,
Liam
