thsBavR10
Re: Cloning a 16GB Class 10 SD card
Mon Feb 04, 2013 7:20 am
It seems that Windows is generally not able to recognize more than one partition on a SD card (removeable media).
http://www.raspberrypi.org/phpBB3/viewt ... 29&t=18581
Win32DiskImager writes raw data, like 'dd' in Linux.
timmoore46
Thu Feb 07, 2013 11:16 am
The Kingston 16GB car was even worse that the ones I normally use.
So shrinking the partition is needed. If only 'Partition Magic' still existed and could cope with Linux Partitions ! *LOL*
Tim
thsBavR10
Thu Feb 07, 2013 3:20 pm
Do you know "Mini tool partition wizard"?
http://www.partitionwizard.com/free-par ... nager.html
It's free.
LemmeFatale
Thu Feb 07, 2013 7:37 pm
timmoore46 wrote:The Kingston 16GB car was even worse that the ones I normally use.
You're likely to find that even two Kingston cards that are ostensibly the same, aren't.
Kingston (as with a great many brands) doesn't manufacture what goes into their cards like, say, SanDisk does, so two seemingly identical Kingston specimens are probably completely different internally, leading to the same result as you've already experienced.
Classic - Raspberry Pi Model B (512MB) with Motorola Atrix Lapdock
Lemcon-One - Raspberry Pi Model B (256MB) PiMAME TV-Box
rfi
Fri Feb 15, 2013 3:07 am
I've been having good results with the 'Paragon Backup & Recovery' tool (free version) for cloning Raspbian images in Windows. It's pretty fast, creates compressed image files, and deals with the problem of different cards being different sizes.
gosciak
Sat Mar 02, 2013 5:01 am
I've recently had the same problem with Lexar Patriot 32GB SDHC. Darn!
