AltumVidetur
Cannot load OpenArena
Mon Jan 28, 2013 12:24 am
Whenever I try to load OpenArena from the Pi Store, it reboots, but does not load OpenArena. Furthermore, the command "openarena" is not recognized in bash. Does anyone have a clue how this might be fixed?
Pankoi
Re: Cannot load OpenArena
Mon Jan 28, 2013 7:29 am
Hi there,
When your Pi reboots and you're at the login prompt, if you press Alt+F8, does it show any errors? Pressing Alt+F1 will let you get back to the login prompt from there. :)
~Richard Williams
The Pi Store: the home of games, apps, tutorials and other content for Raspberry Pi - store.raspberrypi.com
Want to hear about new Pi Store content? Follow @PiStoreReleases on Twitter.
Davespice
Contact: Twitter
Mon Jan 28, 2013 9:46 am
AltumVidetur wrote:Whenever I try to load OpenArena from the Pi Store, it reboots, but does not load OpenArena. Furthermore, the command "openarena" is not recognized in bash. Does anyone have a clue how this might be fixed?
Can you try the procedure here?
http://www.raspberrypi.org/phpBB3/viewt ... 54#p271054
AltumVidetur
Mon Jan 28, 2013 10:02 pm
Pankoi wrote:Hi there,
~Richard Williams
It says "failed to open vchiq instance".
dom
Mon Jan 28, 2013 10:10 pm
AltumVidetur wrote:It says "failed to open vchiq instance".
Sounds like firmware is inconsistent. Try:
sudo apt-get update && sudo apt-get upgrade
if that doesn't work then try rpi-update (https://github.com/Hexxeh/rpi-update)
AltumVidetur
Mon Jan 28, 2013 10:32 pm
Neither of those worked, it returns the same error message.
DrPiD
Tue Jan 29, 2013 8:23 am
Check out the troubleshooting section on this page, it addresses that probably specifically.
Community Manager - IndieCity
AltumVidetur
Sun Feb 03, 2013 3:05 pm
DrPiD wrote:Check out the troubleshooting section on this page, it addresses that probably specifically.
Indeed it does! I followed the recommended solution and now the application generates a different, lengthier error message informing me of the following:
  • I should check that my Q3 executable is in the correct place and that every file in the baseq3 directory is present and readable
  • It couldn't execute q3config.cfg.
  • It couldn't read q3history.
  • My network rate is too slow for VoIP. (Not that I care - I don't even have a mic.)
  • It was unable to open the mouse
  • It could not load OpenGL subsystem.
  • Other messages which I couldn't read due to them scrolling off of the screen.
mrpi64
Fri Mar 01, 2013 2:04 pm
i have heard that openarena is virus ridden with viruses from latvia- dunno if its true or not!
I'm happy to help.
https://www.raspberrypi.org/forums/viewtopic.php?f=78&t=51794 - List of games that work on the Pi.
DrPiD
Fri Mar 01, 2013 2:15 pm
mrpi64 wrote:i have heard that openarena is virus ridden with viruses from latvia- dunno if its true or not!
No, this is not true.
All content is checked by a moderation team at the Raspberry Pi Foundation before it goes live on the site, and if you look on the game page for Open Arena there have been no complaints or issues of this nature.
QBall1977
Sat Apr 27, 2013 2:56 pm
Sounds like a bad install, I had this with Quake 3. I did a complete build again, although did you try this???
sudo usermod -a -G video [your_username]
Currently I can't run Openarea, I just get Err - wrong bpp: 24
____________________________________________
Looking for where to start - try Kernel Panic - http://goo.gl/EEQ5J
