RoyT
running gui from remote terminal
Sun Jan 27, 2013 1:26 pm
Im new to linux is there to run the gui on the raspberry from a remote terminal?
I have been using the raspberry pi from my lap top using putty its been educational and I have a lot to learn .
stevepdp
Re: running gui from remote terminal
Sun Jan 27, 2013 1:59 pm
You'll be looking to set up a VNC server on your Raspberry Pi and a VNC client on your Windows desktop.
There are plenty of tutorials covering how to achieve this. This one is good :-)
jeephour
Sun Jan 27, 2013 5:55 pm
Hi
I'm running
Vinagre is a remote desktop viewer for the GNOME desktop 3.2.1
on Fedora 14 (?) on an asus thing 10" over wifi on a private lan
(pretty usual home wifi to cable ISP)
And ...
tightvncserver on a model b 2 512 raspian wheezy headless
either
connect to default :1 Xwindow session
or
vncserver :2 -geometry 1024x728 -depth 24
And it's easy to use Chrome on the asus to post this.
Any hints?
I'm trying all sorts of stuff in other windows devices so I'll post what I find out here.
ghans
Sun Jan 27, 2013 7:10 pm
You could also try X forwarding :
ssh [email protected]
pcmanfm&
ghans
yakko TDI
Sun Jan 27, 2013 11:18 pm
If you are connecting to the Pi via a Windows machine this may work well for you.
http://www.raspberrypiblog.com/2012/10/ ... -from.html
SimonSmall
Fri Feb 01, 2013 10:01 pm
Just like to echo what yakko said
sudo apt-get install xrdp
wait till it finishes, and it has started the RDP server on the Raspberry Pi. Type "ifconfig" on the Pi to find the Pi's IP address (shown in the "eth0" section not the "lo" section)
Just run the Remote Desktop on the windows machine and use the Pi's IP address - login and you're up and running
AutoStatic
Sat Feb 02, 2013 7:27 pm
ghans wrote:You could also try X forwarding :
pcmanfm&
ghans
I think you forgot to add the -X option?
RPi and real-time, low-latency audio: http://wiki.linuxaudio.org/wiki/raspberrypi
RPi audio repository: http://rpi.autostatic.com/
RPi and audio blog: https://autostatic.com/tag/raspberrypi/
ghans
Mon Feb 04, 2013 7:47 am
Thanks !
The correct command looks like this :
ssh -X [email protected]
pcmanfm&
ghans
