Raikomaru
Re: Max resolution?
Tue Aug 02, 2011 11:53 am
What is the maximum resolution that will be supported?
eben
Re: Max resolution?
Thu Aug 04, 2011 9:23 pm
Max resolution is 1920x1080 on the HDMI port.
Raikomaru
Re: Max resolution?
Fri Aug 05, 2011 2:14 am
Ah, excellent, thank you.
J Sanderson
Re: Max resolution?
Thu Nov 03, 2011 9:17 pm
does the 1080p30 mean it can do 1920x1080 only @ 30Hz?
As far as I've found out a few TV's can do 30Hz and virtually no monitors:-(
Can it do [email protected]
"The GPU is capable of 1Gpixel/s" 1G/(1920x1080)=517 Hz!
Have I got my maths wrong?
I've had a long look on the forum and the FAQ and can see the question asked before but no answer
John
jojopi
Re: Max resolution?
Fri Nov 04, 2011 1:36 am
Quote from J Sanderson on November 3, 2011, 21:17
What information is available about the SoC itself is at least clear on these issues:
http://www.broadcom.com/products/BCM2835
1080p30 is the quoted limit for H.264 video decoding, whereas 1080p60 is supported for the HDMI output.
The gigapixel/s figure quoted is the fill rate. This needs to be comfortably higher than the output clock rate for 2D work, and considerably higher for 3D.
http://en.wikipedia.org/wiki/Fillrate
Of course, the RaspberryPi team will likely not be able to make all of the capabilities of the SoC available. But I suspect no reason that 60Hz monitor output should be a problem.
Re: Max resolution?
Fri Nov 04, 2011 9:12 am
Yes, pretty sure it works with 60Hz - tried on my Dell monitor here via DVI, and also on my Samsung Telly at home with HDMI, and an LG monitor at home with HDMI.
Montekuri
Re: Max resolution?
Fri Nov 04, 2011 2:14 pm
John
The 30 in 1080p30 means 30 progressive frames per second. Not 30Hz
http://en.wikipedia.org/wiki/1080p
na1pir
Re: Max resolution?
Sat Nov 05, 2011 1:00 pm
Ok maximum resolution for hdmi is 1080p, but what for composite output?
kme
Re: Max resolution?
Sat Nov 05, 2011 1:12 pm
Quote from na1pir on November 5, 2011, 13:00
Ok maximum resolution for hdmi is 1080p, but what for composite output?720x576 interlaced @ 50 Hertz for PAL, slightly less for NTSC.
fdufnews
Re: Max resolution?
Sat Nov 05, 2011 1:34 pm
30 progressive frame per second is 30 full image every second so it is 30Hz.
bnolsen
Re: Max resolution?
Sat Nov 05, 2011 2:30 pm
technically I have 3 1920x1200 monitors. 2 have hdmi ports and one (older one) has dvi. they all display at native rez.
I plan on driving one of these monitors with the rpi for testing, although i also have several 1680x1050 monitors as well.
Re: Max resolution?
Sat Feb 21, 2015 3:06 pm
Goechi wrote:http://www.raspberrypi.org/documentatio ... fig-txt.md
Here is your answer guys
When posting, please check the date of the post your are replying to - in this case 2011!!! Before the Pi was launched! This is, I think, the oldest thread resurrection we have ever had.
mimi123
Re: Max resolution?
Sat Feb 21, 2015 4:24 pm
Wow, and for your first post! :shock:
blackketter
Re: Max resolution?
Mon Mar 07, 2016 3:49 pm
Time to resurrect this thread... :)
Has the resolution limit been changed in Raspberry Pi 3?
I'm specifically looking to drive a 2560x1440 display at any frequency.
GTR2Fan
Re: Max resolution?
Mon Mar 07, 2016 3:58 pm
blackketter wrote:I'm specifically looking to drive a 2560x1440 display at any frequency.
Would 2560x1600 be close enough for you? That's been available for a loooooooong time...
http://elinux.org/RPiconfig#Video_mode_options
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
blackketter
Re: Max resolution?
Mon Mar 07, 2016 4:41 pm
Thanks! I'll have to try it. It's surprising that WQHD isn't a supported resolution.
Also still wondering if the maximum pixel clock rate has changed in the RPi3...
GTR2Fan
Re: Max resolution?
Mon Mar 07, 2016 4:55 pm
blackketter wrote:Also still wondering if the maximum pixel clock rate has changed in the RPi3...
As it's still the same GPU as on all previous versions of the Pi, probably not, but I don't know.
If the maximum pixel clock rate achievable is related to GPU clock speed then I guess it may have as that's been increased on the Pi3B, but it's been happy to run overclocked at 500MHz since the Pi2B first arrived, so the same may apply to a tweaked Pi2B also.
I'm out of my depth on this one, so your guess is probably as good as mine. ;)
zombie11
Re: Max resolution?
Tue May 17, 2016 6:51 am
Hi, I'm also trying to have a resolution of 2560x1440 but without success.
Any of you had success?
Thanks.
Gerd
Re: Max resolution?
Tue May 17, 2016 8:16 am
zombie11 wrote:Hi, I'm also trying to have a resolution of 2560x1440 but without success.
Thanks.
See this thread for mor info, especially the posts by dom. viewtopic.php?f=38&t=79330
