pricecw
Re: If you could order now..
Sat Oct 29, 2011 5:22 pm
Been watching this project for quite a while, but just registered to give feedback here. I am excited to see this release, I will order at least 2 model B's as soon as they are available, and probably 2 others, but haven't fully decided on A or B model for those.
sken
Sat Oct 29, 2011 5:45 pm
I would order one per taste just to begin, for my own use.
Then, if feasible, I would like to substitute my board sensors (PIC based) with raspberrypi (probably B version) at work. That means another A and B model for experiments at work.
Total: 2 model A's + 2 model B's.
Nightwing2012
Sat Oct 29, 2011 11:17 pm
Would go for at least one 'A' and two 'B'. A 'B' would be a cool Xmas (Boxing day) gift for a good friend of mine.
For the 'A' I would like to see if I could move from a PCIntell/W2k system that is a icecast station to this! Hang a Hard Drive and a Wireless adapter off of the USB connection. My Friend and I have had a multi year project but most decent boards like this make it to expensive to do. But a 'B' would be ideal!!!!
veronicathecow
Fri Jan 27, 2012 7:42 pm
One model B for me with a possible second one later on. All these model B replies makes me wonder if the model A will actually get produced? I believe the first batch is all "B"'s?
WereCatf
Fri Jan 27, 2012 8:26 pm
I'd probably order 2 or 3 B-models: one for me for all kinds of projects, and the one or two to friends for HTPC uses. Possibly also set up one as a semi-desktop for a friend who is starting to show more than just passing interest in internals of computers.
WereCatf
Fri Jan 27, 2012 8:28 pm
IMHO model A would be much more useful if it sported more USB ports, then it could be used for more diverse projects even though it lacks LAN. Alas, only 1 USB port is too little for anything I have in mind.
Par5pete
Fri Jan 27, 2012 9:26 pm
Hmm....  I would order one for each member of my family & specially my sisters which would benefit them greatly on many different aspects!  So that would Sum up 5 & at least another 2 or 3 for me to use for several applications!
stormy1
Fri Jan 27, 2012 10:55 pm
If there was not a 1 limit I would order 2 at first.
Then if it can do all the projects I have in mind... 7  or 8 more.
Then once I get them working I am sure my family will talk me into giving them to them so another 5 or 6 there.
So 1 for sure 2 very likely and a solid maybe on 12-14 more.
All model Bs
For what I want to use them for the model A isn't that attractive.
Sragir
Sat Jan 28, 2012 1:49 am
I would order 2 model B.
First one to use as a mediaplayer running with XBMC
The second one to experiment with it.
hsoftdev17
Sat Jan 28, 2012 2:07 am
I am not interested in the Model A in the slightest.  I think the 128MB of RAM limitation is likely more cumbersome than the lack of built in ethernet or more than one USB port.  (Network dongles and USB hubs are cheap.)  I would buy a single B now, and then likely augment it with 4 or 5 friends at a later date.  This would give me the extremely cheap means to practice distributed development and dynamic scaleability.
Chris Goodwin
Sat Jan 28, 2012 3:08 am
One or two model B's.
Daniel Tran
Sat Jan 28, 2012 3:25 am
I'd love to have 2 of Model B.
birillo_w
Sat Jan 28, 2012 7:46 pm
for me would be perfect 2 model B"s
acmbc68
Sat Jan 28, 2012 8:04 pm
Half a dozen model Bs to get started - REALLY interested in this for energy management and home automation!!!
From then on, who knows!
hvc123
Sat Jan 28, 2012 8:53 pm
i would have 10
6 model a
4 model b
thats just for projects at my home that i require now.
TonyHoyle
Sat Jan 28, 2012 8:58 pm
I've got plans for 3, maybe 4.
On a similar note, will we be able to donate to the foundation by paying more?
genesispro
Mon Jan 30, 2012 2:38 pm
5 x B for start... I would guess 50 would be the next buy...
aballen
Mon Jan 30, 2012 4:53 pm
If the price lands at $25 I would buy a six pack, of model B
Benj2400
Mon Jan 30, 2012 5:46 pm
2x B version for my first project (I can change the SD to have different project on it) and 3 other for friends.
After this 5 to 10 B version.
Alchemy
Mon Jan 30, 2012 7:17 pm
At first I just need one Model B. First 10,000 batch will go quickly.
Later on about 20 more for a Bramble Cluster(using the cool name even if the config is not technically a cluster). Bramble Clusters should be very quiet. I have a project requiring lots of CPU and have to work in the same room as solution.
Thanks for these products and your brilliant educational aims.
bonzobanana
Mon Jan 30, 2012 8:04 pm
I'm going to order 1 Model B and then expect to order at least 1 more later.
Plan to configure one as a Risc OS computer and another for XBMC.
As the software evolves for it with more mainstream apps etc I'll probably end up with more.
KPR
Mon Jan 30, 2012 9:30 pm
Well I'd love more than one Model B.. So 1 from the first round would make me happy..
It doesn't pay to be greedy!
IDE
Tue Jan 31, 2012 1:04 am
I need two of the latest version. I can't wait, I check this site 3 times a day for updates.
RatCamper
Tue Jan 31, 2012 2:42 am
Well, I'd like lots of them. One B for starters though. I have a million uses for one. And because they come in far cheaper than the most lowly uC board available to me it means that it's possible to reach a lot higher in quality and function of my planned ideas.
jimrcook
Tue Jan 31, 2012 5:05 am
I'm waiting to order 1 B as soon as I can.
