I want to install RaspBMC & RetroPi on my new 512mb Modal B Pi.
What do I need in order to get XBMC & RetoPi working on the same Pi?
Would installing Raspbian as the OS be the best OS option?
Re: Raspbian+RaspBMC+RetroPi Possible?
I'll give you two answers - you choose which one answers your question...
1) Load each of those distributions on separate SD cards. Power off one, swap the card and power up into a different OS
2) Load a card with Berryboot, then you can put several distributions on one card. You still have to reboot to swap distributions though. I am not sure if all distributions are available for Berryboot
On this forum is an explication with uses variosus OS without Berryboot- the info is in spainish, is too simple:
http://www.raspberrypi-spanish.es/foro/ ... t=10#p7847
You can use any OS^^
Salu2.
Salu2.
So I put RaspBMC on one SD card & RetroPi on another SD card & swap between them both?
This won't cause any issues within the raspberry Pi?
That's no problem at all. I have one SD for the raspbmc and other for the raspbian and the RPi is still solid as a rock.Epicvegas wrote:So I put RaspBMC on one SD card & RetroPi on another SD card & swap between them both?
It don't break anything because all the changes you can make in a OS only takes effect on that card. The RPi stills the same.
