Re: About Rasberry lenguage
Hi, im from argentine. im interested in your proyect and I ask if it would be possible to change the OS language to Spanish and as is the way to install Ubuntu on your device.
My understanding is that if Ubuntu, or whatever OS you choose to install on the device, has the option for Spanish then you can use that language. I know that Ubuntu has a Spanish option at install time, but does anyone else know if you can change the OS language post install?
Regardless, worse case scenario you install it fresh yourself. As the R-Pi gets released (or closer to release date at least) I'm sure we'll be getting a lot more instruction on both general use and on how to install ARM11 compatible OSes
Dear forum: Play nice
