G4UFS
Text to speech through a USB sound card
Mon Jan 14, 2013 7:07 pm
I have installed a USB sound card and all is well using MPD but I need to use a text to speech engine that will play through the new USB card.
I have tried, Espeak, Festival, Flite and Google but none of them seem to be configurable to work with the add on sound card.
I believe that it is the sound card device number which is the root cause since configuring MPD to use h1,0 makes it play through it - My USB sound card number shows as "card 1" when I run aplay -l
I am happy to disable the onboard Pi sound card so if there were a way to either configure Espeak to use card 1 or configure the Pi so that the USB card is "0" I think it would all work.
Any ideas?
Dave
-rst-
Re: Text to speech through a USB sound card
Tue Jan 15, 2013 2:14 pm
Search for 'USB audio' on this forum to find instructions how to configure the new device to be the first one. Maybe that would help?
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
G4UFS
Tue Jan 15, 2013 10:37 pm
Thanks for the reply and I have searched the forum but I cannot seem to find anything about making the USB sound card the first device? Have I missed something?
Regards
Dave
-rst-
Wed Jan 16, 2013 11:47 am
G4UFS wrote:Thanks for the reply and I have searched the forum but I cannot seem to find anything about making the USB sound card the first device? Have I missed something?
Regards
Dave
Well, coming up with suitable search keywords is sometimes hard - mostly because there is too much waffle on the internet...
Cloudcentric pointed the relevant wiki section - the 'alsa-base.conf' bit there.
G4UFS
Wed Jan 16, 2013 7:04 pm
Thanks guys. Initially, I missed the top part of the page where it discusses making the card the first one to be detected. Oopps.
I will test this evening and see what I get
Dave
aguirrech
Sun May 12, 2013 7:50 pm
USB sound card must be fixed as hw 0,0 in " /etc/modprobe.d/alsa-base.conf " :
options snd-usb-audio index=0
And make the usb card as the default device in ” /etc/asound.conf ”
Just erase all and replace with this :
pcm.!default {
type hw
card 0
ctl.!default {
type hw
card 0
maxchess42
Thu May 29, 2014 2:26 pm
I had a similar problem with a USB card.
At first neither my USB attached mic or speakers worked.
Then I checked what devices I had using
$ aplay –l
The command the shows the RPI default card as 0 and the USB device as 1
So I put the following in my config file:
pcm.!default {
type hw
card 1
ctl.!default {
type hw
card 1
Note I have Card 1 not 0
After that aplay and a record worked fine through the USB device, but when I installed Espeak it stubbornly refused to find the USB device, gave errors and sent the output through the on-board sound output.
Does anyone know how to fix this, all the discussions I have found so far suggest card 0 might be hard coded into espeak.
Pi A's, Bs, 2s, 3s & zeros 's in Birdboxes, Chess Sets, games, RuneAudio servers Arduinos everywhere else
See: http://www.chess.fortherapy.co.uk\
maxchess42
Thu May 29, 2014 2:39 pm
Ignore my last post, just re-read the previous post and the bit about making the USB as device 0. Works great now with all the stuff as per the original post.
