I have a dozen Sandisk class 10 micro sd cards that I had written an image file to that were a python script running with Raspian Jessie. I've been spending way too much time trying to figure out how to make these all 100% empty and formatted just like the day I bought them. It's an embarrassingly basic question but no matter what I do, there's about 8kb that hangs in there and when I try to write a new image (from another 16gb card, I get "not enough space").
Using windows 7,
I have -- (1) deleted all the files (2) run DISKPART and did a clean, create primary partition and format FAT32. Have used both DISKPART and the SD formatter and it always shows about 8kb of used space. When I "list partition" in DISKPART it shows 1 primary partition at around 14 gb. Also -- the source SD card that I created a new image from is the exact same 16gb sandisk type that I'm trying to write to. I'd buy new ones but there still 6 bucks a piece ! -- thanks for any help
- RaTTuS
- Contact: Twitter YouTube
Re: SD cards -- not enough space -- 8kb?
put in a usb sdcard reader on teh pi
sudo fdisk /dev/sda #<this may be different]
l
d
w
q
[edit]
aha missed that you where trying to write an image to them - not all sdcard are the same size 16Gb is always an approximate with sdcards
l
d
w
q
[edit]
Covfefe
Covfefe
There is no need to reformat or clear a card in any way in order to write an image file to it.
If you find that you get "not enough space" when writing an image that was created from one card onto another card, it will be because the cards are different sizes. SD cards vary a lot in capacity. The size (16GB or whatever) is only an approximate figure. Even cards of the same make and model can vary by a few KB in capacity. The space available on the card is what is left over once any faulty areas have been marked as unavailable by the card.
You either need to find a card that has sufficient capacity for the image, or reduce the size of the image somehow.
Unreadable squiggle
Agree with @rpdom.
However if you want to format you might consider using SD Card formatter, the 'official' one from SD Association.
Who knows knows
Who doesn't doesn't
Who doesn't doesn't
You do not need to format before writing an OS image to the card.
The image contains the entire raw disk, including the partition table.
Therefore any formatting done before the copy is simply overwritten and lost.
Pi4 8GB (Raspberry Pi OS 64-bit), Pi4 4GB, Pi4 2GB, Pi1 Rev 1 256MB, Pi Zero
- CaptainMidnight
Hi mmkw43, if you are able to boot a Pi with the original image that you want to copy and mount another memory card in a card reader attached to one of the USB ports - may I suggest using a script like "rpi-clone" via the command prompt / terminal / ssh session.
https://github.com/billw2/rpi-clone
That script will allow you to duplicate the original booted memory card to a new card sitting in the memory card reader attached to the Pi - as long as there is some free space on the original booted memory card (which I'm sure there probably is) rpi-clone will create a duplicate card - it recreates the original memory card partitions (boot and root) and then only copies the data i.e used space.
You could also try using one of RonR's scripts - image-backup, to create a new smaller backup image from the Pi booted with the original memory card. This newly created image file will be smaller than the image file you are having trouble with and will self expand when booted for the first time on a new card.
viewtopic.php?f=29&t=247568
With this 2nd method, you'll have created a smaller image file that will fit on any 16GB memory card. You may need to ask RonR about his script as I know it works on Buster, probably will, but not sure about Jessie - can't see why not.
"Never get out of the boat." Absolutely goddamn right!
Unless you were goin' all the way...
Ok thanks very much. I remember running into problems a few years back but it didn't register -- so I may try to do my original on an 8gb card and then make images on 16. And will definitely try that clone program. Thanks -- problem solved.
In theory and under Linux, that's true. But on Windows I also sometimes have the issue that Windows doesn't like my sdcards anymore and Windows image writers don't want to write to it. Not sure why that is. If it happens I just zero it with dd on a Linux machine and after that it works again under Windows.There is no need to reformat or clear a card in any way in order to write an image file to it.
To overwrite everything on the card with zeros:
dd if=/dev/zero of=/dev/sdx bs=1M status=progress
