jbobfunky
Raspberry Pi Diagnostics
Thu Dec 03, 2020 10:50 am
Hello and hope all is well and safe!
This morning I noticed a neat little program called Raspberry Pi Diagnostics in the RPi 3. Cool... Apparently it checks the SD card write and read speeds..... and mine FAILED! Huh?
I'm running a Onn 32G SD Card. Yea.. not super name brand but its been working as my main card.
I also have a Samsung 32G Evo Plus clone of Onn SD card. Freshly cloned with the SD Card Copier. Super name brand... that FAILED too!!
Here's what the detail of that diagnostic run...
Raspberry Pi Diagnostics - version 0.5
Thu Dec 3 04:33:51 2020
Test : SD Card Speed Test
Run 1
prepare-file;0;0;9598;18
seq-write;0;0;9465;18
rand-4k-write;0;0;632;158
rand-4k-read;8164;2041;0;0
Sequential write speed 9465 KB/sec (target 10000) - FAIL
Note that sequential write speed declines over time as a card is used - your card may require reformatting
Random write speed 158 IOPS (target 500) - FAIL
Random read speed 2041 IOPS (target 1500) - PASS
Run 2
prepare-file;0;0;9653;18
seq-write;0;0;10505;20
rand-4k-write;0;0;638;159
rand-4k-read;8026;2006;0;0
Sequential write speed 10505 KB/sec (target 10000) - PASS
Random write speed 159 IOPS (target 500) - FAIL
Random read speed 2006 IOPS (target 1500) - PASS
Run 3
prepare-file;0;0;16185;31
seq-write;0;0;14000;27
rand-4k-write;0;0;308;77
rand-4k-read;8547;2136;0;0
Sequential write speed 14000 KB/sec (target 10000) - PASS
Random write speed 77 IOPS (target 500) - FAIL
Random read speed 2136 IOPS (target 1500) - PASS
Test FAIL
I was like wow on both cards FAILING the test.
I guess the questions are...
What's the deal with this and what should I do? If something should be done...
And
What are the best SD cards to use for these things?
Thanks in advance!!
~ jbobfunky
topguy
Re: Raspberry Pi Diagnostics
Thu Dec 03, 2020 11:12 am
Do you have other programs/services running in the background when running these tests ?
There is this other small command line tool called "dstat" that can show system load for CPU/disk/network.
The values it checks against seem to be for Class A1 cards.
