Hello im creating a pcb for my my zero (w) aside from the circuit that is special to my application, i also need LAN connection via ethernet, that i need to place on the same pcb. Internet searches led me to ENC28J60 which uses the SPI. My concern is that this chip is over 5 years old, andd is wondering if there are newer alternatives.
Can anyone suggest a newer alternative to ENC28J60. I am a hardware person so please suggest IC that takes little to no effort in setting up in linux as i only know the basics.
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
Re: A modern alternative to ENC28J60
Afaict the ENC28j60 is about 14 years old (first edition of the datasheet was released in January 2006, though sometimes datasheets come out before the chips do), The ENC424j600 is only slightly newer with the first edition of the datasheet being published in 2009.
I wouldn't let that put you off the chips though, Microchip are pretty damn good at keeping stuff in production for the long haul.
It seems to me that the main advantage of the ENC424j600 over the ENC28j60 is that it supports 100 megabit operation. While as of right now most ports still support 10 megabit, at some point 2.5G/5G/10G ethernet will become more common and ports that support speeds beyond 1 gigabit tend not to support 10 megabit operation. I'm not sure if anyone has had it working with a Raspberry Pi though, google didn't seem to turn up much.
Thank you sir the article you linked even has schematics.DougieLawson wrote: http://dangerousprototypes.com/docs/ENC ... kout_board
A quick question does this IC if i buy it fresh from digi-key still need to be programmed?
Dont get me wrong, im fine with old chips, im just a bit worried in the future since i will most probably recycle the circuit i will make here in the future. Using newer chips with newer protocols just give me a bit more flexibility of the circuit whatever i may use it in the future.plugwash wrote: I wouldn't let that put you off the chips though, Microchip are pretty damn good at keeping stuff in production for the long haul.
From what i understood the ENC424j600 interfaces to the raspberry pi via SPI, I think 100megabit is as far as it can go. Going into gigabit territory would mean needing the SPI to run on atleast a gigabit which is i dont think any raspberry pi can do for now. Making the 100megabit my most likely candidate.plugwash wrote: It seems to me that the main advantage of the ENC424j600 over the ENC28j60 is that it supports 100 megabit operation. While as of right now most ports still support 10 megabit, at some point 2.5G/5G/10G ethernet will become more common and ports that support speeds beyond 1 gigabit tend not to support 10 megabit operation. I'm not sure if anyone has had it working with a Raspberry Pi though, google didn't seem to turn up much.
Are you aware if the raspberry pi os natively supports this chip or atleast there are good ready made drivers. Im not really experienced tinkering with linux
ENC424J600 supports 10/100BASE-T but you can't get 100Mbps throughput with it as its SPI interface is only capable of 14Mbps.JakeQuinn wrote: ↑Tue Nov 17, 2020 12:43 pmFrom what i understood the ENC424j600 interfaces to the raspberry pi via SPI, I think 100megabit is as far as it can go. Going into gigabit territory would mean needing the SPI to run on atleast a gigabit which is i dont think any raspberry pi can do for now. Making the 100megabit my most likely candidate.
That is unfortunate. I see that if make a raspberry pi specific circuit 10 is the only way.
I could still use the ENC424J600 but now only for the future recycalability of the circuit.
A device working at gigabit speeds does not require the Pi's SPI has to work at gigabit speeds. In fact the ENC424j600 which handles 100Mbps has SPI which is only 14Mbps capable.JakeQuinn wrote: ↑Tue Nov 17, 2020 12:43 pmFrom what i understood the ENC424j600 interfaces to the raspberry pi via SPI, I think 100megabit is as far as it can go. Going into gigabit territory would mean needing the SPI to run on atleast a gigabit which is i dont think any raspberry pi can do for now.
