Beorn_Bear
Cooling Raspberry Pi Zero
Thu Nov 12, 2020 10:32 pm
I am currently using a Raspberry Pi Zero as a Pi-Hole. When running "vcgencmd measure_temp" in the command line, it shows that the Raspberry Pi Zero Temp = 54.1C. I am using an Aluminium heat sink. I also have spare copper heat sinks. Would a Copper Heat Sink provide better cooling?!
dustnbone
Re: Cooling Raspberry Pi Zero
Thu Nov 12, 2020 11:00 pm
Nothing wrong with 54C. You're still a very long way from having any kind of temperature related issues.
Thu Nov 12, 2020 11:06 pm
There's no need for a heatsink of any flavour on a Zero. Even if you run a flat out, non-yeilding loop you can't get a single core ARM6 to run hard enough to get to 85°.
Imperf3kt
Contact: Twitter
Fri Nov 13, 2020 12:35 am
Regarding copper, it won't do any better than aluminium.
Though it has a higher thermal conductivity, it has a lower specific heat capacity. A combination of the two would work marginally better.
But as others have said, a Pi Zero doesn't need a heatsink at all and would be a waste of raw materials.
55:55:44:44:4C
52:4C:52:42:41
pidd
Fri Nov 13, 2020 1:18 am
Only true for same weight of heatsinks, for two dimensionally equal heatsinks copper will be better than aluminium both in the short term (heat soak) and in the long term.
LTolledo
Fri Nov 13, 2020 9:18 am
my versions...
RPiZW Aluminum heatsink-case view2.jpg (165.76 KiB) Viewed 558 times
and this one below has caused a very serious uproar :mrgreen:
but hey... these are mine.... not theirs....
Some people be like:
AndrewPiEater
Fri Nov 13, 2020 9:52 am
No need for cooling on a Pi Zero in normal ambient temperatures.
I put one at the top of an antenna mast and the heat from direct sunlight in the summer did for it.
Beorn_Bear
Fri Nov 13, 2020 6:31 pm
Now there is a flirc case for the Raspberry PI zero. It might be a worthwhile option.
scruss
Fri Nov 13, 2020 6:44 pm
If you want to waste your money, yeah. But Raspberry Pi Zeroes are almost impossible to overheat from processor load.
Pronouns: he/him
echmain
Sat Nov 14, 2020 2:02 am
my versions...
Where did you get that aluminum case for the Zero? Looks very nice.
I tried a bunch of Google searches but couldn’t find it.
LTolledo
Sat Nov 14, 2020 3:35 am
my versions...
I got it from amazon about 2 years ago, got two versions of it (GPIO covered and GPIO exposed).
sad to say its no longer available.....
echmain
Sat Nov 14, 2020 10:37 am
my versions...
Ah well, thanks anyway. I snoozed, I losed.
