Cooling Raspberry Pi Zero
I am currently using a Raspberry Pi Zero as a Pi-Hole. When running "vcgencmd measure_temp" in the command line, it shows that the Raspberry Pi Zero Temp = 54.1C. I am using an Aluminium heat sink. I also have spare copper heat sinks. Would a Copper Heat Sink provide better cooling?!
Re: Cooling Raspberry Pi Zero
Nothing wrong with 54C. You're still a very long way from having any kind of temperature related issues.
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
There's no need for a heatsink of any flavour on a Zero. Even if you run a flat out, non-yeilding loop you can't get a single core ARM6 to run hard enough to get to 85°.Beorn_Bear wrote: ↑Thu Nov 12, 2020 10:32 pmI am currently using a Raspberry Pi Zero as a Pi-Hole. When running "vcgencmd measure_temp" in the command line, it shows that the Raspberry Pi Zero Temp = 54.1C. I am using an Aluminium heat sink. I also have spare copper heat sinks. Would a Copper Heat Sink provide better cooling?!
Regarding copper, it won't do any better than aluminium.
Though it has a higher thermal conductivity, it has a lower specific heat capacity. A combination of the two would work marginally better.
But as others have said, a Pi Zero doesn't need a heatsink at all and would be a waste of raw materials.
55:55:44:44:4C
52:4C:52:42:41
Rose tinted glasses are difficult to see through.
52:4C:52:42:41
Only true for same weight of heatsinks, for two dimensionally equal heatsinks copper will be better than aluminium both in the short term (heat soak) and in the long term.
my versions...
and this one below has caused a very serious uproar
but hey... these are mine.... not theirs....
Some people be like:
No need for cooling on a Pi Zero in normal ambient temperatures.
I put one at the top of an antenna mast and the heat from direct sunlight in the summer did for it.
Now there is a flirc case for the Raspberry PI zero. It might be a worthwhile option.
If you want to waste your money, yeah. But Raspberry Pi Zeroes are almost impossible to overheat from processor load.Beorn_Bear wrote: ↑Fri Nov 13, 2020 6:31 pmNow there is a flirc case for the Raspberry PI zero. It might be a worthwhile option.
‘Remember the Golden Rule of Selling: “Do not resort to violence.”’ — McGlashan.
Pronouns: he/him
Pronouns: he/him
I got it from amazon about 2 years ago, got two versions of it (GPIO covered and GPIO exposed).
sad to say its no longer available.....
