jbobfunky
Desktop Shortcut to Folder?
Tue Nov 03, 2020 11:51 am
Hi everyone,
It's been a while and I hope everyone is well and safe in this crazy world we have here.
Quick Question:
What are the exact steps to create a Desktop Shortcut to a Folder???
My Pi 4 is a little web server I've created.
I simply want a shortcut to the site files on my desktop that points and opens the folder in /var/www/html. That's it.
I've looked at pretty much every thing.
1 - Can't seem to get any example to actually work.
2 - Crazy but... there seems to be no clear and concise example on this. At least not to me. (newb with a little bit of legs grown here, apologies up front)
Anyway, clear direction on this is really appreciated and thank you for your time!!
~ jbobfunky
~ jbobfunky
kerry_s
Re: Desktop Shortcut to Folder?
Tue Nov 03, 2020 12:14 pm
ln -s /var/www/html ~/Desktop/
rpdom
Tue Nov 03, 2020 12:23 pm
Drag the directory from File Manager onto the desktop and it will create a shortcut.
Or from the command line:
pi@raspberrypi:~ $ ln -s /path/to/your/directory ~/Desktop
Change "/path/to/your/directory" to be the directory you want to make a link to.
Unreadable squiggle
klricks
Tue Nov 03, 2020 12:46 pm
Drag the directory from File Manager onto the desktop and it will create a shortcut.....
Doesn't work for me.
pidd
Tue Nov 03, 2020 1:52 pm
Looks like you need permissions on the directory? I successfully did it with Mypython directory from the right hand pane of the filemanager. Other random directories didn't work from outside my home directory.
jbobfunky
Tue Nov 03, 2020 3:22 pm
Hmmm.....when I drag that html folder to my desktop it actually moves the whole folder... so that doesn't seem to work for me.
~ jbobfunky
jbobfunky
Tue Nov 03, 2020 3:28 pm
Hey the command worked! Wow thanks y'all! This is a huge help. Surprised its not more straight forward. Should be in the right click list of options on a folder. Any thanks again! This problem is solved!
~ jbobfunky
klricks
Tue Nov 03, 2020 8:55 pm
I found that holding the [Ctrl] key while left dragging from the right pane works.
