dsyleixa123
retrieve a file location by recognizing only the link of the file
Thu Oct 01, 2020 10:46 am
hello,
I have a file link on my Stretch Desktop, related to a file stored somewhere in any a nested subdir.
Reading the link's property informations, it shows the path of the link (home/pi/Desktop) but I can't recognize the path of the origin (the whole path is reduced/truncated and so unreadable corrupted)...
what am I missing?
jahboater
Re: retrieve a file location by recognizing only the link of the file
Thu Oct 01, 2020 11:26 am
Does the "file" command help?
$ file joe
joe: symbolic link to fred
Pi4 8GB running PIOS64 Lite
dsyleixa123
Thu Oct 01, 2020 1:30 pm
yes, thank you, a little cumbersome (as usual for Linux), but it works! :mrgreen:
jahboater
Thu Oct 01, 2020 2:22 pm
"ls" of course can do it too, I just use "file" out of habit:
$ ls -l joe
lrwxrwxrwx 1 jah jah 4 Oct  1 15:18 joe -> fred
or the standard alias (which is better because it shows its a directory):
$ ll joe
lrwxrwxrwx 1 jah jah 4 Oct  1 15:18 joe -> fred/
If you think "ll" is too cumbersome, then it would be trivial to write a small C program, giving you a command with the name or syntax you prefer:
See "man 2 open" and look at the options O_NOFOLLOW and O_PATH
or just use an alias:
alias follow_soft_link file
dickon
Thu Oct 01, 2020 2:40 pm
realpath is more useful, as it will follow all the symlinks in the path and return the canonical name:
newdesktop:/tmp/ (1) 42 $ touch a
newdesktop:/tmp/ (1) 43 $ ln -s a b
newdesktop:/tmp/ (1) 44 $ ln -s b c
newdesktop:/tmp/ (1) 45 $ realpath c
/tmp/a
newdesktop:/tmp/ (1) 46 $
jahboater
Thu Oct 01, 2020 2:48 pm
Cool!
There is readlink too, but it only opens the first file.
dsyleixa123
Thu Oct 01, 2020 3:19 pm
thanks for the friendly advices!
All terminal commands work, but what I meant what would be more convenient is if one could read all path information just out of the link-file properties, e.g. by enlarging the properties window or scroll through the explicite uncorrupted pathname . :geek: :ugeek: :? 8-)
jahboater
Thu Oct 01, 2020 5:10 pm
It is the contents of the soft link file, not its properties.
Soft links were invented to allow a link to cross filesystem boundaries.
dsyleixa123
Thu Oct 01, 2020 5:32 pm
the target file+path is supposed to be shown in the linkfile-properties, and in fact, actually it's there - but totally corrupted and unreadable.
jahboater
Thu Oct 01, 2020 5:45 pm
Hard links work by having two entries in a directory (which is a file containing filename/inode number pairs) with the same inode number. Thus the file has two names. They are indistinguishable from each other.
The trouble with that is file system specific, the inodes are local to the filesystem.
Soft links work by having the filename of the target file contained within another file. Nothing to do with inodes, and so the filename or path name of the target file may easily point to another filesystem. Its as simple as that.
There is a mode bit set in the soft link file to say what it is. The system will automatically and transparently open the soft link file, read the new path from the file, and use that.
dickon
Thu Oct 01, 2020 5:54 pm
Nit pick: the directories with the two (or more) entries do not have to be the same.
newdesktop:/tmp/ (1) 78 $ mkdir d
newdesktop:/tmp/ (1) 79 $ ln a d/a
newdesktop:/tmp/ (1) 80 $ ls -li a d/a
4295316 -rw------- 2 dickon dickon 0 Oct  1 18:51 a
4295316 -rw------- 2 dickon dickon 0 Oct  1 18:51 d/a
newdesktop:/tmp/ (1) 81 $
OP appears to be using some sort of file manager, which displays the link contents when requested. But it mangles them. I have no answer to that as I simply don't use one and wouldn't know where to begin.
newdesktop:/tmp/ (1) 81 $ pgrep xterm | wc -l
104
newdesktop:/tmp/ (1) 82 $
jahboater
Thu Oct 01, 2020 6:02 pm
Yes. Of course.
I was trying to keep the explanation reasonably simple to illustrate the difference between hard and soft links!
Like not mentioning reference counts and deletion.
dsyleixa123
Thu Oct 01, 2020 7:56 pm
no, you do not understand: the linked original file+path (target) is visible in the desktop linkfile properties, but totally truncated, mutilated, corrupted, and thus messed up and unreadable. But the target name is expected to be written out completely.
Like e.g., when opening the link's properties (context menu):
file name: logfile_pi07.dat
exploited pathname to origin, visible:
target: /home/pi/s...pi07.dat
explicitely it must be instead
/home/pi/settings/backup/logfile_pi07.dat
