Schorschi
How to install mariadb 10.5 on Pi OS?
Thu Sep 17, 2020 5:44 pm
Latest version available in raspbian repo is only 10.3.x. Tried to setup a repo...
# sudo apt install software-properties-common dirmngr
# sudo apt-key adv --fetch-keys 'https://mariadb.org/mariadb_release_signing_key.asc'
# sudo add-apt-repository 'deb [arch=amd64] http://sfo1.mirrors.digitalocean.com/mariadb/repo/10.5/debian/dists/buster main'
Get the following error...
aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template for Raspbian/buster
Which makes sense given there is no official Raspbian support?
Re: How to install mariadb 10.5 on Pi OS?
Thu Sep 17, 2020 5:58 pm
Adding an amd64 repository is pointless. Raspberry Pi OS is armhf (with an arm64 version currently in Beta). amd64 code is for 64-bit PCs, not Pis.
Are you sure you need 10.5? It doesn't even look like 10.5 will be in the next release of Raspberry Pi OS or Debian. They're currently sticking with 10.3 from what I can see. although 10.5.5 is currently in Debian Experimental, so maybe it will be added to Bullseye if there is time.
Unreadable squiggle
geev03
Thu Sep 17, 2020 6:29 pm
This is from Bullseye,testing
root@raspberrypi:~# uname -a
Linux raspberrypi 5.8.0-1-arm64 #1 SMP Debian 5.8.7-1 (2020-09-05) aarch64 GNU/Linux
root@raspberrypi:~# mysql -u root -p
Enter password:
Welcome to the MariaDB monitor.  Commands end with ; or \g.
Your MariaDB connection id is 54
Server version: 10.3.24-MariaDB-2 Debian buildd-unstable
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]> SELECT VERSION();
| VERSION()         |
| 10.3.24-MariaDB-2 |
1 row in set (0.000 sec)
MariaDB [(none)]> exit
Bye
root@raspberrypi:~#
Thu Sep 17, 2020 7:08 pm
The only Linux Operating System which offers 10.5 is ArchLinuxArm as far as I am aware:
https://archlinuxarm.org/packages
Thinking outside the box is better than burying your head in the sand...
sounds81
Sat Sep 26, 2020 5:00 am
Add this line
sudo dpkg --get-selections |
Then this one
sudo dpkg-reconfigure mysql-server-5.5
