zahroc
System Dashboard for Raspberry Pi 4?
Thu Aug 20, 2020 7:21 pm
I just found this older repository, https://github.com/matematik7/rpi-dashboard , that is a system dashboard for the Pi. It hasn't been updated in years and the author said it should still work. I am going to give it a try but I figured I would ask if anyone has used something else similar? Up to date? Maybe a docker version?
Sample attached.
TIA!
hammersxo
Re: System Dashboard for Raspberry Pi 4?
Fri Aug 21, 2020 7:37 am
Sample attached.
TIA!
Hey, can you update the results as you try them? I'm pretty keen to know.
[moderator removed hidden spamlink, and banned poster]
CaptainMidnight
Fri Aug 21, 2020 1:28 pm
Sample attached.
TIA!
Have you looked at something like RPi- Monitor ?
https://xavierberger.github.io/RPi-Moni ... tures.html
"Never get out of the boat." Absolutely goddamn right!
Unless you were goin' all the way...
zahroc
Fri Aug 21, 2020 1:52 pm
Sample attached.
TIA!
Looks promising! I will check it out. Thanks!
Botspot
Tue Oct 13, 2020 10:10 pm
You may want to check out Conky. It's a little system monitor that sits on your desktop.
Want to run Minecraft Java on your RPi? Easiest way is with Pi-Apps - just click Install.
https://github.com/Botspot/pi-apps
Pi-Apps also includes Zoom, Visual Studio, Tor browser, Windows 10 theme, and 33 more.
Over 50,000 users!
Moonmarch
Tue Oct 13, 2020 10:17 pm
I was about to suggest Conky. The Conky program will appear on the desktop after launching the program. You can install Conky using the command in the terminal:
sudo apt install conky-all
You can always use the Task Manager to monitor computer resources. Task Manager does not include many computer monitoring features compared to Conky. You can add Panel Applets to the Task Bar to add computer resource monitors to the desktop. To add computer resource monitors to the Task Bar, right click on the Task Bar, and choose Add / Remove Panel Items.
zahroc
Tue Oct 13, 2020 10:58 pm
Thanks for the conky reference. I will check it out. Currently I am running my Pi headless for this project but for connected Pis, conky could be a choice.
Botspot
Tue Oct 13, 2020 11:07 pm
Yeah, if you want to go down that route, don't be surprised when your conky looks terribly ugly. And conky won't start automatically on boot either.
If you want my custom config, and have conky start on boot, the easiest way is with Pi-Apps. (a simple RPi app store I made)
full list conky.png (220.54 KiB) Viewed 160 times
Over 50,000 users!
