sim_tcr
php web hit counter question.
Fri Jan 04, 2013 1:52 pm
I am running on raspbian wheezy, apache2 and php5.
I have implemented a php web counter at http://raspisimon.no-ip.org (right bottom of the page). Code is below,
counter.php
<?php
$count_my_page = ("hitcounter.txt");
$hits = file($count_my_page);
$hits[0] ++;
$fp = fopen($count_my_page , "w");
fputs($fp , "$hits[0]");
fclose($fp);
echo $hits[0];
index.php
<?php
echo "Total Visits:";
include ("counter.php");
Is there a way to make the counter to record hits only from outside internet. In other words prevent counter from recording hits from (192.168.1.0 to 192.168.1.255)?
Raspberry Pi Model B x 2, Raspberry Pi 2 x 2, Transcend 32GB Class 10, Transcend 16GB Class 10, Transcend 8GB Class 4, Custom 12V 1.5A (stepped down to 5.5V)
++bahjatk++
Re: php web hit counter question.
Fri Jan 04, 2013 2:30 pm
$_SERVER['REMOTE_ADDR']
returns the IP of the client. You can do something like this :
if (strrpos($_SERVER['REMOTE_ADDR'],"192.168.1")==0) {
//do not ++
} else {
$hits[0]++;
sim_tcr
Sat Jan 05, 2013 4:21 am
//do not ++
} else {
$hits[0]++;
I added above code to my counter.php and it looks like below now,
//do not ++
} else {
$hits[0]++;
$hits[0] ++;
fclose($fp);
echo $hits[0];
Still when I browse from localhost it counts the hit.
efflandt
Sat Jan 05, 2013 7:49 am
localhost (yourself) is not an IP that begins with 192.168. IP (that is a private LAN IP).
localhost is an IP that begins with "127." so you also want to avoid counting hits from that.
sim_tcr
Sat Jan 05, 2013 7:57 am
efflandt wrote:localhost (yourself) is not an IP that begins with 192.168. IP (that is a private LAN IP).
Could you please modify my code above and reply?
++bahjatk++
Sun Jan 06, 2013 10:54 am
sim_tcr wrote: I added above code to my counter.php and it looks like below now,
//do not ++
} else {
$hits[0]++;
$hits[0] ++;
fclose($fp);
echo $hits[0];
you got it all wrong...
Code should like this :
//do not ++
} else {
$hits[0] ++;
fclose($fp);
echo $hits[0];
it still counts the hit because you placed your own hit counter outside the if... else... statement.
If you do that code and it stills counts the hit, try replacing the "192.168.1" part with "127.0.0" as efflandt suggested
efflandt wrote:localhost is an IP that begins with "127." so you also want to avoid counting hits from that.
sim_tcr
Sun Jan 06, 2013 11:12 am
++bahjatk++ wrote: Code should like this :
//do not ++
} else {
$hits[0] ++;
fclose($fp);
echo $hits[0];
Tried above one, but nothing is counted either from outside or inside.
++bahjatk++
Sun Jan 06, 2013 12:55 pm
//do not ++
} else {
$hits[0] ++;
fclose($fp);
echo $hits[0];
Hmmm...
to test it out, do echo $_SERVER['REMOTE_ADDR'];
then replace the argument in the if like this :
if ($_SERVER['REMOTE_ADDR']=="the output") {
where "the output" is a quote, followed by what you got from echoing $_SERVER['REMOTE_ADDR'], followed by another quote.
