AkulaMD wrote: ↑Tue Aug 11, 2020 4:17 pm
W. H. Heydt wrote: ↑Tue Aug 11, 2020 4:11 pm
AkulaMD wrote: ↑Tue Aug 11, 2020 3:51 pm
I know. My question was to determine whether or not this was applied even at the peak demand during the lockdown. Or did other manufacturer help to fullfil the high demand during that period?
Why would it matter? All Pis of any model are made to the same specs, regardless of where the assembly takes place. Might as ask if manufacturing the SoCs was farmed out to companies other than TSMC.
Of course it does matter. That might explain why we have issues with soldering quality as discussed in other thread. Or perhaps it's just a problem with Sony UK.
That issue has been raised and dismissed for pretty much very model of Pi ever released. There will always be some residual level of manufacturing defects. For Pis, it is actually very low. If you want to know where a given Pi was assembled, start by looking at the PCB. You will find a "country of origin" label there. Past that, some of the internal ID codes will tell you what company did the assembly work. (Note that I say "assembly" because the parts on the PCB--and the PCB itself--could come from anywhere, though for the small components that will largely be China. The major chips will be sourced from the companies whose names appear on them and the ultimate source will depend on who owns the fab where they were actually made. In the case of the Broadcom SoC, that is TSMC--and they have fabs in--IIRC--both Taiwan and mainland China.)
Beyond that, if you happen to get an actually defective Pi, which is to say that a problem *isn't* user error, then the RPT is interested so that they can examine it and--at need--talk to the assembly plant managers to fix the QC failure.
I have Pis from both China and the UK. There are no functional differences.
This is, however, rather far afield from the question about the Pi2B2 being discontinued, which it hasn't been. The only Pis I know of---off hand--that have actually been discontinued (not to be confused with the more general RPF/RPT products) are the original Model B (with only two USB ports, replaced with the 4-port version) and the Model A (replaced, ultimately, with the A+). My personal regret is that the official RPF WiFi dongle was discontinued, but that is probably largely due the advent of Pis with integral WiFi.
