Hello guys,
I'm about to use a raspberry on my car, when the car turns on the raspberry should turns on to and turns off when the car turns off so... what is the best and safest way to do this ?
Re: Doubt about Safe Shutdown
include this IC to your possible solution:
Some people be like:
- thagrol
- Contact: Website
If you need to write to the Pi's storage some sort of UPS is the way to go. IF you don't need to write mount everything, including the root partition read only - there are options in raspi-config to do this with an overlay.
For the read only route, power your pi from any accessory live suupply via a suitable buck converter. It'l boot when you turn the key to the accessory position and power will be cut when you turn the car off. One caveat: most cars will briefly cut the accessory power when the starter is used so expect a reboot at that point.
All advice given is based on my experience. it worked for me, it may not work for you.
All GPIO pin numbers are BCM numbers.
