Hi All,
We need some ideas regarding Boot Over Ehternet.
We are attempting Boot Over Ehternet from a Linux Server to a cluster of Raspberry Pis.
For example: We have an image of Raspbian on a Linux Server from where the cluster of RPIs can be booted-up?
The RPIs are Power over Ethernet, PoE hats and have Raspbian pre-installed. The image can be booted-up automatically when a new RPI is introduced into the system?
Please post some ideas.
Thank You.
Best Regards,
Ahsan
Tampere University.
Re: Boot Over Ehternet- Linux Server to Raspberry Pis
This seems quite a good documentation on that topic: https://www.raspberrypi.org/documentati ... utorial.md
Hi All,
Thank you for the answer.
We have been following the tutorial. It refers to Boot using a Server Rpi to Client Rpi.
We have a Ubuntu (linux) Server with Raspbian image, the desired result is to somehow ''Mount'' the image, so that the Cluster of RPis can be booted-up using Ethernet? The image can be booted-up automatically when a new RPI is introduced into the system?
BR,
Ahsan
BR,
Ahsan
