Issue: When i turn the Raspberry on, the Power LED goes on just for a second and then goes off. The Recalbox boots normally, but neither the Power nor the Reset button respond at all.
When i switch the internal switch to OFF, everything works fine, it just has hard Reset and shutdown.
Here is what i got back when installing the script, just to be sure, because i don't understand these things:
wget -O - "https://raw.githubusercontent.com/RetroFlag/retroflag-picase/master/recalbox_install_gpi.sh" | bash--2020-07-24 20:58:33-- https://raw.githubusercontent.com/RetroFlag/retroflag-picase/master/recalbox_install_gpi.shResolving raw.githubusercontent.com... 199.232.16.133Connecting to raw.githubusercontent.com|199.232.16.133|:443... connected.HTTP request sent, awaiting response... 200 OKLength: 1286 (1.3K) [text/plain]Saving to: 'STDOUT'
100%[===================>] 1.26K --.-KB/s in 0s
2020-07-24 20:58:33 (12.7 MB/s) - written to stdout [1286/1286]
--2020-07-24 20:58:37-- https://raw.githubusercontent.com/RetroFlag/retroflag-picase/master/recalbox_SafeShutdown_gpi.pyResolving raw.githubusercontent.com... 199.232.16.133Connecting to raw.githubusercontent.com|199.232.16.133|:443... connected.HTTP request sent, awaiting response... 200 OKLength: 818 [text/plain]Saving to: '/opt/RetroFlag/SafeShutdown.py'
/opt/RetroFlag/Safe 100%[===================>] 818 --.-KB/s in 0s
2020-07-24 20:58:37 (6.66 MB/s) - '/opt/RetroFlag/SafeShutdown.py' saved [818/818]
grep: S99RetroFlag: No such file or directoryExecutable S99RetroFlag configured.RetroFlag Pi Case Switch installation done. Will now reboot after 3 seconds.WARNING: could not determine runlevel - doing soft reboot(it's better to use shutdown instead of reboot from the command line)
Broadcast message from root@RECALBOX (Fri Jul 24 20:58:42 2020):
The system is going down for reboot NOW!
