SE43
Re: Is this the correct Micro USB cable needed for the Pi?
Tue Jan 31, 2012 10:25 pm
http://www.amazon.co.uk/Micro-.....038;sr=1-1
Is this correct, just about to buy it.
JeremyF
Tue Jan 31, 2012 10:41 pm
Yes. Although I would shy away from something so cheap if you can, but that's me being a skeptic so you're probably fine.
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
Lynbarn
Tue Jan 31, 2012 11:17 pm
Depends what you want to use it for. The USB ports on the 'Pi are full size (the "A" end of the cable you show) The micro-USB (the "B" end) would be suitable for power supply only, which you could use from, for example, a PC.  I don't believe the micro-USB on the 'Pi carries any signal lines.
grumpyoldgit
Tue Jan 31, 2012 11:20 pm
There are some really stinking reviews about the quality though. Issues about the cable not allowing devices to charge properly and also falling apart. I might have to spend the extra 9p and get one from Poundland!
liz
Tue Jan 31, 2012 11:24 pm
I am not sure whereabouts in the forums it is (do a search on "wet string"), but Dom bought a 99p USB cable that you put 5V in one end of, and which produced 4V at the other. Caveat emptor. Personally I'd suck it down and spend a bit more, and forgo the day's coffee.
grumpyoldgit
Tue Jan 31, 2012 11:26 pm
But if you put in 4V from the other end can you get 5V out of it?
Lynbarn
Tue Jan 31, 2012 11:28 pm
So - if he'd plugged it in the other way around, maybe he would have got 6V out!
