For some people many of your "disadvantages" are actually "advantages" or are irrelevant (*), especially if you don't want to run Windows 10, then buy a Pi.
PeterO
(*) I've only ever put a PC into hibernation by mistake !
Hibernation is useful on Win10 because it is so slow to boot -- it saves oodles of time especially on a low-end laptop without SSD.
....well my w$ experience is getting worse and worse.... if that counts....Is Pi4 desktop experience supposed to be this bad?
Yes, I’d still prefer Linux. Windows is, and always has been (I have experience using and programming for it going back to before 3.0 was public) horrible.GlowInTheDark wrote: ↑Wed Aug 12, 2020 3:00 pmSo, given all that, can you make an argument that you'd still prefer that the Pi run Linux? Wouldn't you have to concede in that case, we'd just run Windows on it? And that, thus, we're really only liking Linux because it is there - because we can.
No I would still run Linux.GlowInTheDark wrote: ↑Wed Aug 12, 2020 3:00 pmSo, given all that, can you make an argument that you'd still prefer that the Pi run Linux? Wouldn't you have to concede in that case, we'd just run Windows on it? And that, thus, we're really only liking Linux because it is there - because we can.
But, Windows is not freely available. It also MUCH easier to port Linux to run on A.N.Other board than Windows, as shown by the fact that MS support only a tiny number of non-x86 devices (they used to support more - Alpha for example). So its quite possible that even if Windows HAD been available, Linux would still be chosen because it was so much easier to get it working on the Pi. Its not just availability that is important, but easy of porting.GlowInTheDark wrote: ↑Wed Aug 12, 2020 8:06 pmThanks for the responses, but you (both of the last two responders) are missing the point.
OF COURSE, you and I prefer Linux, but we are not the general public.
The point is that if Windows had been freely available, I am sure it would have been used. Because the world should be about keeping the general public happy, not about geeks like us.
Linux was only used because it was available.
As far as I can tell, the reason the Raspberry Pi exists at all is because the needs of young people learning programming are rather different than the general public. In order to fill the niche it was designed for, the Pi needed to be different than the existing Windows and Macintosh computers.GlowInTheDark wrote: ↑Wed Aug 12, 2020 8:06 pmThanks for the responses, but you (both of the last two responders) are missing the point.
No.Wouldn't you have to concede in that case, we'd just run Windows on it? And that, thus, we're really only liking Linux because it is there - because we can.
No. You miss the point.Thanks for the responses, but you (both of the last two responders) are missing the point.
Windows is 'popular' only because it is widely available and aggressively pushed on hardware makers by Microsoft. In some fairer word, Microsoft would have been given huge fines for anti-competitive behavior. (One thing would be reading about OS2 for instance). Many people that use computers learn how to use it by using Windows and by default assume that is 'good'. I'm sure that there are many examples in history where in general people behaved that way - would pick sub quality stuff over much better (maybe even cheaper!) only because 'they use to' using worse one.GlowInTheDark wrote: ↑Wed Aug 12, 2020 3:00 pmSo, given all that, can you make an argument that you'd still prefer that the Pi run Linux? Wouldn't you have to concede in that case, we'd just run Windows on it? And that, thus, we're really only liking Linux because it is there - because we can.
Certainly I can deny an obvious fallacy.GlowInTheDark wrote: ↑Wed Aug 12, 2020 3:00 pmBut you can't deny that it just makes everything harder.
Discuss.
In my view; yes. Most 'learning to program stuff' doesn't depend upon the OS at all. If the Raspberry Pi and Linux disappeared tomorrow they would still continue their educational mission.GlowInTheDark wrote: ↑Wed Aug 12, 2020 3:00 pmSurely, the stated educational goals of the Pi would work just as well under Windows as under Linux.
Exactly. That's exactly what I'm saying.hippy wrote: ↑Thu Aug 13, 2020 10:49 amIn my view; yes. Most 'learning to program stuff' doesn't depend upon the OS at all. If the Raspberry Pi and Linux disappeared tomorrow they would still continue their educational mission.GlowInTheDark wrote: ↑Wed Aug 12, 2020 3:00 pmSurely, the stated educational goals of the Pi would work just as well under Windows as under Linux.
And let's not forget that Linux had been around for decades before the Raspberry Pi emerged. It wasn't lack of Linux which was holding kids back from learning to code. It wasn't Microsoft or Windows either.
Except in my experience it's the wide range of peripherals for the PI that let you easily learn about "physical computing" (from blinking a led, to building weather stations) that get the most enthusiastic responses from youngsters, certainly more that anything just screen based. This is where (again IME) using PIs and Arduinos get much better results. And now the cost of such hardware is no longer determined by how much greedy hardware suppliers think schools will pay for PC compatible hardware. They can't rip them off like they used to do !hippy wrote: ↑Thu Aug 13, 2020 10:49 amIn my view; yes. Most 'learning to program stuff' doesn't depend upon the OS at all. If the Raspberry Pi and Linux disappeared tomorrow they would still continue their educational mission.GlowInTheDark wrote: ↑Wed Aug 12, 2020 3:00 pmSurely, the stated educational goals of the Pi would work just as well under Windows as under Linux.
I have to disagree. Having a computing curriculum that was dumbed down to just learning how to use MS office suite must have put off several generations of youngsters, and that was the problem for Cambridge University that the PI was intended to address. Of course it's now had a much wider impact than was originally hoped for.And let's not forget that Linux had been around for decades before the Raspberry Pi emerged. It wasn't lack of Linux which was holding kids back from learning to code. It wasn't Microsoft or Windows either.
It's not a direct relationship that you should be looking for. It's several indirect consequences of the RPF choosing Linux that have made it such a success.GlowInTheDark wrote: ↑Thu Aug 13, 2020 11:00 amThere's nothing intrinsic about Linux (in 2020) that makes it central to the educational mission of the RPF.
Don't you think it was the evangelism of Eben and the RPF, the community and the low cost that really made the difference there? If MSWin was free and running on similarly cheap hardware and a similar campaign was run I think it could have been similarly effective. Of course those are unrealistic IFs. Cost was a vital element and MS wasn't going to give away their golden goose.PeterO wrote: ↑Thu Aug 13, 2020 11:13 amI have to disagree. Having a computing curriculum that was dumbed down to just learning how to use MS office suite must have put off several generations of youngsters, and that was the problem for Cambridge University that the PI was intended to address. Of course it's now had a much wider impact than was originally hoped for.
PeterO
No. Certainly if there had been another OS that a) worked on the Pi without major corporate headaches, b) was free (or reasonably priced), and c) gave you easy access to I/O functions, that might have worked too.PiGraham wrote: ↑Thu Aug 13, 2020 11:28 amDon't you think it was the evangelism of Eben and the RPF, the community and the low cost that really made the difference there? If MSWin was free and running on similarly cheap hardware and a similar campaign was run I think it could have been similarly effective. Of course those are unrealistic IFs. Cost was a vital element and MS wasn't going to give away their golden goose.PeterO wrote: ↑Thu Aug 13, 2020 11:13 amI have to disagree. Having a computing curriculum that was dumbed down to just learning how to use MS office suite must have put off several generations of youngsters, and that was the problem for Cambridge University that the PI was intended to address. Of course it's now had a much wider impact than was originally hoped for.
PeterO
It wasn't Linux that changed the curriculum.
Again you're looking for a direct cause and effect where none exists. It's all about the indirect consequences of the choices made at the start that came together to make the success story.
Yes.
Actually I'm doing the opposite. I'm agreeing that there are many 'causes' and Linux is not essential, although it is important.
Yes, but then if the RPF had gone with RISCOS or whatever people probably would use that, and it would be maintained and polished to similar level, and some would still be moaning that it isn't Windows while most use it happily.jahboater wrote: ↑Thu Aug 13, 2020 12:15 pm
But any Pi owner is free to install whatever OS they like on it. So if there was a demonstrably better option than Linux, people can and probably would use it. In practice the well maintained and user friendly Linux distro called Raspbian is chosen by most users.
