bvb40170
HDMI cable and Pi4b case
Sat Jul 11, 2020 8:01 pm
Hi! I've tried several micro cables on my Pi 4b fitted into a 4b case but the plug does not fit completely into the micro HDMI sockets because of the thickness of the plastic case. The result is no connection to the monitor. Can anyone recommend a cable that will fit into what appears to be the standard opening for the micro HDMI plug or a case with a bigger opening to accept a standard micro HDMI plug?
Alternatively is there a workaround for this?
drgeoff
Re: HDMI cable and Pi4b case
Sat Jul 11, 2020 8:15 pm
Enlarge the hole in the plastic case?
W. H. Heydt
Sat Jul 11, 2020 9:00 pm
Dremel. Attack either the cable strain relief or the case. Your choice.
mooblie
Sat Jul 11, 2020 10:44 pm
This shows two similar, but different, Pi4 cases:
Guess which one has problems with HDMI cables? Which is your case like?
cleverca22
Sun Jul 12, 2020 2:55 am
bottom looks much better, even getting the SD card out of the top one would be a nightmare, did they even try using it?? lol
bvb40170
Sun Jul 12, 2020 9:19 am
Thanks everyone! As simple as taking the Dremel to it!
