sam18
recommendations for graphic programming in rpi?
Mon Jul 06, 2020 3:11 pm
hi, i am trying to create a graphic display for my project, however i am not sure of what program to use.
basically, i have to connect my rpi to a hdmi display to show my condition's outcome based on my sensor readings for room occupancy.
i did android studio for awhile previously and i've checked online but reading my sensor's values from my rpi and linking it to android studio seems a little too difficult for me, is there any other method to recommend?
i heard that python has a graphic programming, may i know is there any helpful websites or videos to look at?
i kind of want the display to look like that:
Annotation 2020-07-06 230858.jpg (20.86 KiB) Viewed 404 times
B.Goode
Re: recommendations for graphic programming in rpi?
Mon Jul 06, 2020 3:31 pm
A couple of options. (There are many more... )
guizero https://lawsie.github.io/guizero/
pysimplegui https://github.com/PySimpleGUI/PySimple ... /readme.md
rpiMike
Mon Jul 06, 2020 3:56 pm
pygame is another
clicky
Mon Jul 06, 2020 4:15 pm
pygame is another
I concur. Pygame is good place to start with.
neilgl
Mon Jul 06, 2020 4:19 pm
Have a look at YAD and others mentioned in this post https://www.raspberrypi.org/forums/vie ... 1&t=267834
and is that pressure sensor code working now?
sam18
Tue Jul 07, 2020 1:02 am
okay, thank you. i will try it out!
neilgl wrote: and is that pressure sensor code working now?
i have updated my code, but there is a slight problem, i've posted it on my another post!
sam18
Wed Jul 22, 2020 2:40 pm
is there a way for the display to loop? as i am reading from sensors that are continuously getting new readings, the display only reads my reading once and display the results once, i have to close and run again for the next reading
neilgl
Wed Jul 22, 2020 3:05 pm
Not sure what you have coded it in now, but for python with tkinter you can use a timer to regularly update the display.
