Which "it" ?techjonte7272 wrote: ↑Sun Jul 05, 2020 11:57 amIt says that the media is writeprotected when I try to save after I changed the gpu_mem to 128
If your using an SD card adapter (https://www.amazon.com/SanDisk-microSD- ... B0047WZOOO) there is a switch on the side for write protection. You might want to try flipping that switch and see if that resolves your write protection problem.techjonte7272 wrote: ↑Sun Jul 05, 2020 12:15 pmI’m using a 64 bit windows 10 to edit but does it work on windows 7?
