Schorschi
Raspberry Pi OS Upgrade from Stretch To Buster
Sun Jun 28, 2020 4:43 pm
To upgrade from stretch to buster, is this not the correct steps?
1. Edit source files to reflect buster rather than stretch
2. Execute apt update
3. Execute apt upgrade
4. Execute apt dist-upgrade
5. Reboot
6. apt --purge autoremove
Apparently the above is incomplete, but it sure did update a lot of packages.
After reboot, i check the /etc/os-release file, and it still shows the stretch information?
# cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
VERSION_CODENAME=stretch
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
And... lsb_release is not right...
# lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 9.11 (stretch)
Release:        9.11
Codename:       stretch
Re: Raspberry Pi OS Upgrade from Stretch To Buster
Sun Jun 28, 2020 4:46 pm
3. Execute apt dist-upgrade
4. Reboot
VERSION_ID="9"
ID=raspbian
ID_LIKE=debian
# lsb_release -a
Release:        9.11
Codename:       stretch
Going from one release to another is not recommended, but read the bottom of the Official Blog for details:
https://www.raspberrypi.org/blog/buster ... -raspbian/
Thinking outside the box is better than burying your head in the sand...
Schorschi
Sun Jun 28, 2020 5:10 pm
True, major release to major release is a potential pit fall. But I have one Pi device I cannot take the time to build from scratch right now. Still, this is something that should not result in files not being update correctly. I realize this likely a Debian core issue, but Raspberry Pi foundation or whatever they are called now, has great impact on Debian OS, financially if not literally.
Above said, clearly the base files did not upgrade as I expected...
# apt-cache policy base-files
base-files:
  Installed: 9.9+rpi1+deb9u11
  Candidate: 9.9+rpi1+deb9u11
  Version table:
 *** 9.9+rpi1+deb9u11 500
        500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
        100 /var/lib/dpkg/status
RonR
Sun Jun 28, 2020 8:12 pm
One thing missing from your list is expanding the BOOT partition to 256 MiB. The Buster files won't fit in the existing Stretch partition.
Mon Jun 29, 2020 7:10 am
Which source files did you change?
What is the output of apt policy?
It looks like you still have some of the files pointing to stretch.
Unreadable squiggle
pi-anazazi
Mon Jun 29, 2020 12:20 pm
From the official blog post linked above:
1. In the files /etc/apt/sources.list and /etc/apt/sources.list.d/raspi.list, change every use of the word “stretch” to “buster”.
... I did that with good success in the past...
Kind regards
anazazi
