Giga_Pi
Gnome For Pi: A script to make installing GNOME easier [BETA]
Thu Jun 18, 2020 4:09 pm
Hello everyone!
Today, I created a new script that should make installing GNOME on your Pi easier.
https://github.com/TerraGitHuB/gnomeforpi
Apart from confirming installation of GNOME packages, it is pretty much autonomous.
My full guide is here:
viewtopic.php?f=66&t=276512
To use the script:
git clone https://github.com/TerraGitHuB/gnomeforpi.git
cd gnomeforpi
sudo bash install.sh
You will need to disable the animations yourself (working on it), and you'll also need to enable fakeKMS openGL driver in raspi-config, but everything else should be fine.
Once you get to the login screen, you'll need to change the session to "GNOME on Xorg"
This is my first bit of code I have ever published to the world. Enjoy!
Giga_Pi
GNOME for Pi
A project to get the popular GNOME desktop to run on Raspberry Pi OS.
Guide here: https://www.raspberrypi.org/forums/viewtopic.php?f=66&t=276512
Source code here: https://github.com/TerraGitHuB/gnomeforpi
Pi4 4GB with Manjaro ARM KDE
Giga_Pi
Re: Gnome For Pi: A script to make installing GNOME easier.
Fri Jun 19, 2020 5:04 am
Bump
GNOME for Pi
kerry_s
Fri Jun 19, 2020 5:38 am
why are you bumping?
i suspect very few use gnome on there rpi4.
those that do can handle installing on there own.
i only install what i need & would never install the full gnome, just enough gnome to work.
anyways, right now for my rpi4 4gb i have grown fond of budgie.
a "lighdm budgie-desktop" install is bare bones & lets you select all your apps. of course just like gnome it has some quirks. you still have to do the "tsched=0" to fix pulse audio stutter & disable the dhcpd.service to get wifi. fix the sudo(polkit) verification so it don't ask for root password, etc...
but since your not confined to gnome apps, you can lighten the load. you can make it very light with "lxterminal, pcmanfm, mousepad" like raspbian but with a better overall gui.
this 1 i'm running now has "nemo, lxterminal, mousepad" for the main apps. nemo file manager is a fork of nautilus for cinnamon desktop. just trying it out.
Screenshot from 2020-06-18 19-36-44.png (133.48 KiB) Viewed 559 times
Screenshot from 2020-06-18 19-28-31.png (147.81 KiB) Viewed 559 times
Giga_Pi
Fri Jun 19, 2020 7:01 am
Sorry for bump.
I wanted to make installing GNOME desktop easier, and then I made the script.
If you look at the source code, it does more than just install: It also does some configuring too.
GNOME for Pi
kerry_s
Fri Jun 19, 2020 7:44 am
yeah, i did look at it.
you can trim it down.
apt-get install -y xorg gnome gnome-shell
to just
apt install -y gnome-shell
it will pull in the rest. including the "chrome-gnome-shell" so you don't have to add that.
i'd recommend installing chromium
apt install -y rpi-chromium-mods
for this, it's just locked to pi. people might add other users.
cp localauthority.conf /etc/polkit-1/localauthority.conf.d/60-localauthority.conf
i create "/etc/polkit-1/localauthority.conf.d/51-admin.conf" with this.
[Configuration]
AdminIdentities=unix-group:sudo
mind you, i already have a lot of the gnome stuff installed, so my list is short. but you get the jest of it.
Screenshot from 2020-06-18 21-41-54.png (114.56 KiB) Viewed 527 times
Giga_Pi
Fri Jun 19, 2020 7:55 am
to just
[Configuration]
Thanks, I've commited some of those changes. I also added some audio fixes as well.
GNOME for Pi
kerry_s
Fri Jun 19, 2020 8:10 am
combine all the "apt -y install" lines, no need to do it many times.
example:
apt install -y gnome-shell rpi-chromium-mods
you can "touch" & "echo" the file 51-admin.conf in the script, there's no need for a separate file to copy(cp)
same thing for the fixes you can search & replace in a file to fix that /etc/pulse/default.pa
(line #47 in my editor)
load-module module-udev-detect tsched=0
anyways, i'm sure it'll be useful to somebody who's to new to dive in. :D
good luck.
Giga_Pi
Fri Jun 19, 2020 8:18 am
example:
good luck.
Thanks for your exceptional help once again!
GNOME for Pi
kerry_s
Sat Jun 20, 2020 12:33 pm
i owe you an apology my friend. seems like somethings changed and some recommends no longer gets pulled in.
here's what i used for a minimum gnome install. hope it helps ya out.
#!/bin/sh
sudo apt update; sudo apt -y full-upgrade; sudo apt -y autoremove; sudo apt clean
sudo apt install -y gnome-session gnome-shell nautilus gedit gnome-terminal seahorse gnome-tweaks rpi-chromium-mods
sudo touch /etc/polkit-1/localauthority.conf.d/51-admin.conf
sudo sh -c 'echo "[Configuration]" >> /etc/polkit-1/localauthority.conf.d/51-admin.conf'
sudo sh -c 'echo "AdminIdentities=unix-group:sudo;unix-group:admin" >> /etc/polkit-1/localauthority.conf.d/51-admin.conf'
sudo sed -i 's/load-module module-udev-detect/load-module module-udev-detect tsched=0/g' /etc/pulse/default.pa
sudo systemctl disable dhcpcd.service
sudo reboot
exit 0
[code]
Screenshot from 2020-06-20 03-28-12.resized.png (153.88 KiB) Viewed 419 times
kerry_s
Sat Jun 20, 2020 9:38 pm
the command to disable animation is:
gsettings set org.gnome.desktop.interface enable-animations false
kms is enabled by default so no need to worry about that.
also i was thinking, maybe add the "New File" in templates. i still can't understand why that has to be done manually. :?
touch /home/pi/Templates/"New File"
kerry_s
Sun Jun 21, 2020 1:07 am
looks like any settings for the user(pi) can't be made till after log in.
so:
this is useless in the script. :(
i'll look for a work around later.
Giga_Pi
Sat Jul 04, 2020 7:31 am
so:
Thanks. Sorry, I thought this thread had died long ago.
Ok. Time to review. I wondering how on earth they got desktopify to work for ubuntu. Looking at it soon.
GNOME for Pi
Giga_Pi
Sat Jul 04, 2020 7:35 am
so:
I'm just going to shoot this idea at you: Could create a script that does this on login, that then destroys itself?
GNOME for Pi
kerry_s
Sat Jul 04, 2020 7:50 am
they just using a bash script.
https://github.com/wimpysworld/desktopi ... desktopify
you can script a 1 time run script.
sorry under the weather today, eyes to blurry to see.
Giga_Pi
Sat Jul 04, 2020 9:32 am
I've added an argument for GNOME with a limited amount of packages (-l/--lite)
I may have fixed audiio issues, but not sure.
GNOME for Pi
Giga_Pi
Re: Gnome For Pi: A script to make installing GNOME easier [BETA]
Sun Jul 05, 2020 8:36 am
There is now a Beta and stable branch to Gnome For Pi
GNOME for Pi
