tipam
New 3D printed Pi4 case designs for overclocking
Thu Jun 18, 2020 2:34 pm
Hi
If anyone is interested, I've posted new 3D printable, Pi4 cases for overclocking on Thingiverse
Both cases have instructions and can slide onto a stand.
I'm currently working on adding an SSD housing as well (built into the stand).
The cases use either a 30x30x7mm 5V fan or the ICE Tower fan;
[edit] If anyone has an idea they'd like to see in/on/for a Pi4 case let me know :mrgreen:
Raspberry Pi == small computer == big dreams
RaspbianUser1
Re: New 3D printed Pi4 case designs for overclocking
Thu Jun 18, 2020 3:50 pm
I have to admit, they are really nice. I had to look real hard to find any fault with it :lol:
That one fault is the part above the red piece, it is a bit thin and with too much pressure with the red piece, it could break and then the grille could be loose and need to be fixed.
But apart from that I really like it, the fact it fits with the ice tower fan is a bonus
Running Raspberry Pi OS Full, therefore my comments will be based on that
Using RPI-4B 4GB at 2.1GHz CPU and 700MHz GPU
don't format your sd because someone said so.
Or put your favourite cutlery into your nearest outlet (May result in death) ;)
BeauSlim
Thu Jun 18, 2020 5:54 pm
Lots of good ideas in your design. I particularly like the stand. Thanks for sharing!
tipam
Thu Jun 18, 2020 6:06 pm
The red piece is pretty tough (5mm thick) ... you only see a thin rim once it's pushed into the back of the case. I suppose the fan holder is thin but it needs to have some flex to securely hold the fan.
Thanks for taking a look - you're comments are very helpful :)
trejan
Thu Jun 18, 2020 6:16 pm
Case looks good. I'm not sure about using PLA for it though. The glass transition temperature of PLA is well within the normal operating temperature range of a Pi 4.
tipam
Thu Jun 18, 2020 7:36 pm
Good point ... the Pi board is approx. 1.5mm from bottom of the case resting on edge supports and has a vent underneath. Continuous cooling of the board should also be sufficient - however I wouldn't recommend using the case without a fan.
BeauSlim
Thu Jun 18, 2020 10:12 pm
I have printed PLA parts for use on my Pi4. I have only seen slight warping on one piece and that was a "harness" I designed to hold a large heat sink down on top of a thermal pad and then connect to the board at the 4 screw points. So basically a combination of thin structural members, torque from perpendicular forces, and direct contact with chunk of hot metal caused warping. It still works fine.
tipam
Fri Jun 19, 2020 3:07 pm
Just added back to back stand and stackable SSD drive mount (available on the same Thingiverse page https://www.thingiverse.com/thing:4463789)
Here are some configurations ...
