Possum
Can I run agnostics from the Terminal
Wed Jun 17, 2020 3:27 am
Hi
Can I run agnostics from the Terminal to do a SD Card Speed Test. If I can where can I find any data on how to do this..?
Thank You..
klricks
Re: Can I run agnostics from the Terminal
Wed Jun 17, 2020 4:20 am
Hi
Thank You..
Not sure what data you are looking for?
To run from terminal open lxterminal and enter:
agnostics
Note that agnostics is a GUI program which requires Desktop.
CaptainMidnight
Wed Jun 17, 2020 6:03 am
Hi
Thank You..
Do you mean do this .......
pi@phoenix-pi-x64:~ $ sh /usr/share/agnostics/sdtest.sh
Run 1
prepare-file;0;0;327680;640
seq-write;0;0;330989;646
rand-4k-write;0;0;87732;21933
rand-4k-read;62894;15723;0;0
Sequential write speed 330989 KB/sec (target 10000) - PASS
Random write speed 21933 IOPS (target 500) - PASS
Random read speed 15723 IOPS (target 1500) - PASS
"Never get out of the boat." Absolutely goddamn right!
Unless you were goin' all the way...
wildestpixel
Wed Jun 17, 2020 6:19 am
Hi
Thank You..
Run 1
This is the helpful answer - thanks
much solution-ness - https://www.wildestpixel.co.uk
Possum
Wed Jun 17, 2020 9:51 pm
Thx.. That exactly what I needed..
Cheers
Possum
Thu Jun 18, 2020 5:28 pm
Going by this I must have very poor MicroSDs. That would be true or is there something I need to know.
pi@raspberrypi:~ $ sh /usr/share/agnostics/sdtest.sh
Run 1
prepare-file;0;0;9293;18
seq-write;0;0;10146;19
rand-4k-write;0;0;929;232
rand-4k-read;3731;932;0;0
Sequential write speed 10146 KB/sec (target 10000) - PASS
Random write speed 232 IOPS (target 500) - FAIL
Random read speed 932 IOPS (target 1500) - FAIL
CaptainMidnight
Thu Jun 18, 2020 5:41 pm
IF you have a desktop gui, you could also use the benchmark feature in gnome-disk-utility.
I say 'IF' as your request was asking '.... from the Terminal' ;)
Edit: it'll also allow you to access any S.M.A.R.T data available from the drive.
pfletch101
Thu Jun 18, 2020 11:12 pm
Run 1
The software Doc warns that it needs to be run on a 'virgin' SD. If a SD has been in a live system for any length of time, and has had stuff written on and deleted from it, you are likely to get artificially low numbers, even on a good SD. I am not sure how one might go about returning a used SD to a 'virgin' state for testing.
HvdW
Sun Sep 27, 2020 10:49 pm
prepare-file;0;0;11330;22
seq-write;0;0;12661;24
rand-4k-write;0;0;1090;272
rand-4k-read;5928;1482;0;0
Sequential write speed 12661 KB/sec (target 10000) - PASS
Random write speed 272 IOPS (target 500) - FAIL
Random read speed 1482 IOPS (target 1500) - FAIL
On a 2014 model B, 8G Sandisk Ultra
The fact that it's able running Buster is more important than speed.
Who knows knows
Who doesn't doesn't
cleverca22
Sun Sep 27, 2020 11:20 pm
root@raspberrypi:~# /usr/share/agnostics/sdtest.sh
Run 1
prepare-file;0;0;4403;8
seq-write;0;0;4357;8
rand-4k-write;0;0;2038;509
rand-4k-read;9210;2302;0;0
Sequential write speed 4357 KB/sec (target 10000) - FAIL
Note that sequential write speed declines over time as a card is used - your card may require reformatting
Random write speed 509 IOPS (target 500) - PASS
Random read speed 2302 IOPS (target 1500) - PASS
Run 2
prepare-file;0;0;5529;10
seq-write;0;0;3723;7
rand-4k-write;0;0;460;115
rand-4k-read;9083;2270;0;0
Sequential write speed 3723 KB/sec (target 10000) - FAIL
Random write speed 115 IOPS (target 500) - FAIL
Random read speed 2270 IOPS (target 1500) - PASS
root@raspberrypi:~# df -h /
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        15G   12G  2.5G  83% /
just to see how my pi was performing, i gave it a spin, and the numbers seemed pretty bad
but then i deleted ~6gig worth of unused files, ran a trim, and gave it another spin
root@raspberrypi:~# fstrim -v /
/: 6.2 GiB (6612336640 bytes) trimmed
Run 1
prepare-file;0;0;16491;32
seq-write;0;0;14854;29
rand-4k-write;0;0;2719;679
rand-4k-read;9291;2322;0;0
Sequential write speed 14854 KB/sec (target 10000) - PASS
Random write speed 679 IOPS (target 500) - PASS
Random read speed 2322 IOPS (target 1500) - PASS
/usr/share/agnostics/sdtest.sh: line 34: return: can only `return' from a function or sourced script
Run 2
prepare-file;0;0;8562;16
seq-write;0;0;16765;32
rand-4k-write;0;0;2805;701
rand-4k-read;9243;2310;0;0
Sequential write speed 16765 KB/sec (target 10000) - PASS
Random write speed 701 IOPS (target 500) - PASS
Random read speed 2310 IOPS (target 1500) - PASS
/dev/root        15G  5.8G  8.0G  43% /
and now sequential writes are ~5x faster, and random writes dont horribly tank when it runs a second pass
bensimmo
Mon Sep 28, 2020 7:49 am
Run 1
not necessarily, the benchmark pass is quite high, it's based around modern A1 card speeds on modern Pi3 onwards (or similar cards that can do the same).
It's the random that would generally fail.
Older Pi also get much lower benchmarks than faster more modern Pi.
What are you running it on and what Pi is it?
