I have found that since the release of the Raspberry Pi 3, new Pis have been able to boot from a USB but is it possible for the raspberry pi B+ model?
If yes then what i need to do to boot up raspberry pi B+ model using USB drive?
Abhishek533 wrote: ↑Tue Jun 16, 2020 1:02 pmI have found that since the release of the Raspberry Pi 3, new Pis have been able to boot from a USB but is it possible for the raspberry pi B+ model?
Pi3B and Pi2Bv1.2 can have the OTP bit set and then be booted directly from a USB mass storage device (MSD), such as a USB stick.pidd wrote: ↑Tue Jun 16, 2020 2:01 pm3B+ can, 4B+ is on it way and is currently very promising in beta
https://www.raspberrypi.org/documentati ... des/msd.md
There is no 4B+ model.
The 3B can, but it needs to have a special OTP bit set to enable USB booting.Abhishek533 wrote: ↑Tue Jun 16, 2020 1:02 pmI have found that since the release of the Raspberry Pi 3, new Pis have been able to boot from a USB but is it possible for the raspberry pi B+ model?
If you are referring to the old Pi1 model B+ then, no, it will not boot directly from USB. Models other than those mentioned above require a FAT32 formatted SD card with the bootcode.bin file on it.Abhishek533 wrote: ↑Tue Jun 16, 2020 1:02 pmIf yes then what i need to do to boot up raspberry pi B+ model using USB drive?
I dunno... The sequence is pretty easy to keep track of, with the aside of the Pi0/Pi0W/Pi0WH, which are (respectively) the base version, same with added WiFi capability, and the installing header pins at the factory. In terms of SoC, they are all generation one boards, despite the '0' in the designations.jbudd wrote: ↑Tue Jun 16, 2020 7:41 pmAll this confusion over Raspberry Pi models is making my brain ache!
As a nod to Debian, please can future models be given real names? I suggest characters from great works of English fiction.
Pooh, Piglet, Eeyore, Kanga, Roo, Tigger, Rabbit, Owl
Or avoiding any question of copyright: Peaseblossom, Cobweb, Moth, Mustardseed, Oberon, Titania, Puck
