Command not working from script but on command line - why?
Posted: Mon Jun 15, 2020 8:03 pm
System:
RPi4 running Raspbian Buster fully updated.
ffmpeg is version: 4.1.4-1+rpt7~deb10u1
I have created a script to automate a video cropping function executed via ffmpeg.
In principle the script looks like this with error catching removed:
The script file is set to executable and placed in /home/pi/bin
In another dir /home/pi/video I have a test video file.
So from the video dir I issue the following command and get the error:
So I tested again using the command that was printed to the console as part of script operation:
And when it all ends I have the cropped video!
QUESTION:
Why is this not working when I run the exact same command from within the script????
And what can I do to fix it?
#!/bin/bash
CROP="$1"
SOURCEFILE="$2"
TARGETFILE="$3"
COMMAND="ffmpeg -i $SOURCEFILE -filter:v \"crop=in_w:in_h-$CROP\" -c:a copy -hide_banner $TARGETFILE"
echo "Command to execute: $COMMAND"
$COMMAND
$ cropvideoh 40 videotest.mp4 crop40.mp4
Command to execute: ffmpeg -i videotest.mp4 -filter:v "crop=in_w:in_h-40" -c:a copy -hide_banner crop40.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'videotest.mp4':
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
encoder : Lavf58.29.100
Duration: 00:02:00.00, start: 0.000000, bitrate: 237 kb/s
Stream #0:0(und): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuv420p(tv, bt709), 320x240 [SAR 1:1 DAR 4:3], 135 kb/s, 25 fps, 25 tbr, 12800 tbn, 50 tbc (default)
Metadata:
handler_name : ISO Media file produced by Google Inc. Created on: 06/15/2020.
Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 96 kb/s (default)
Metadata:
Stream mapping:
Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264))
Stream #0:1 -> #0:1 (copy)
Press [q] to stop, [?] for help
[AVFilterGraph @ 0x7bb460] No such filter: '"crop' <==== ERROR HERE!!!!!
Error reinitializing filters!
Failed to inject frame into filter network: Invalid argument
Error while processing the decoded data for stream #0:0
Conversion failed!
$ ffmpeg -i videotest.mp4 -filter:v "crop=in_w:in_h-40" -c:a copy -hide_banner crop40.mp4
Metadata:
major_brand : isom
minor_version : 512
Metadata:
Metadata:
Stream mapping:
[libx264 @ 0x21c7e70] using SAR=1/1
[libx264 @ 0x21c7e70] using cpu capabilities: ARMv6 NEON
[libx264 @ 0x21c7e70] profile High, level 1.3
[libx264 @ 0x21c7e70] 264 - core 155 r2917 0a84d98 - H.264/MPEG-4 AVC codec - Copyleft 2003-2018 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
Output #0, mp4, to 'crop40.mp4':
Metadata:
major_brand : isom
minor_version : 512
encoder : Lavf58.20.100
Stream #0:0(und): Video: h264 (libx264) (avc1 / 0x31637661), yuv420p, 320x200 [SAR 1:1 DAR 8:5], q=-1--1, 25 fps, 12800 tbn, 25 tbc (default)
Metadata:
encoder : Lavc58.35.100 libx264
Side data:
cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: -1
Metadata:
frame= 3000 fps=281 q=-1.0 Lsize= 2529kB time=00:01:59.97 bitrate= 172.7kbits/s speed=11.2x
video:1025kB audio:1407kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 3.983594%
[libx264 @ 0x21c7e70] frame I:16 Avg QP:18.72 size: 14149
[libx264 @ 0x21c7e70] frame P:1222 Avg QP:22.55 size: 594
[libx264 @ 0x21c7e70] frame B:1762 Avg QP:31.51 size: 55
[libx264 @ 0x21c7e70] consecutive B-frames: 14.7% 15.8% 15.2% 54.3%
[libx264 @ 0x21c7e70] mb I I16..4: 11.6% 13.5% 74.9%
[libx264 @ 0x21c7e70] mb P I16..4: 0.7% 0.3% 0.2% P16..4: 19.0% 6.6% 4.5% 0.0% 0.0% skip:68.6%
[libx264 @ 0x21c7e70] mb B I16..4: 0.0% 0.0% 0.0% B16..8: 11.2% 0.7% 0.1% direct: 0.2% skip:87.8% L0:36.7% L1:60.3% BI: 3.0%
[libx264 @ 0x21c7e70] 8x8 transform intra:19.4% inter:43.7%
[libx264 @ 0x21c7e70] coded y,uvDC,uvAC intra: 56.8% 77.6% 59.5% inter: 4.0% 5.6% 1.6%
[libx264 @ 0x21c7e70] i16 v,h,dc,p: 15% 75% 5% 5%
[libx264 @ 0x21c7e70] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 33% 24% 3% 3% 4% 5% 4% 5%
[libx264 @ 0x21c7e70] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 23% 34% 12% 4% 5% 5% 6% 5% 6%
[libx264 @ 0x21c7e70] i8c dc,h,v,p: 26% 51% 18% 5%
[libx264 @ 0x21c7e70] Weighted P-Frames: Y:0.3% UV:0.1%
[libx264 @ 0x21c7e70] ref P L0: 80.8% 7.8% 8.9% 2.5% 0.0%
[libx264 @ 0x21c7e70] ref B L0: 91.3% 7.6% 1.1%
[libx264 @ 0x21c7e70] ref B L1: 96.6% 3.4%
[libx264 @ 0x21c7e70] kb/s:69.95
QUESTION:
