Hi guys,
for my current project I need the Raspberry to be running 24/7 connected to my network via WiFi.
I used 2 different adapters, but none of them worked for more than ~12 hrs before spamming the syslog with strange errors.. (One of them I even bought at modmypi).
Is there anybody successfully using the PI 24/7 with a wifi connection?
Re: Which WiFi adapter
It would most likely be a problem with the software your running rather than the adapter itself what do you have installed. What were the errors reported. I have an edup and some other similar chips they all run without any errors.
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
i use a Ralink(Rt5370) chipset based wifi dongle.. cheaply available out there.. can also be used as a hotspot..
i was going to ask the same question but in a much less intelligent fashion...martinm wrote:Hi guys,
i can't get my RTL 8187 adapter to go more than half a day or so before it chokes and loses connectivity (linux noob so i don't know where to look for actual error messages - the adapter sure gets warm, though). got a D-Link w/ AR5523 chipset that i can't get working at all...am going to try a Zonet (marvell chipset) dongle next, as soon as i get the strength to go through the ordeal of getting it to work.
but it did lead me to wonder if there are long-term wifi success stories, as the op has asked. i did spring for the Pluggable 5-port powered USB hub, which makes WiFi work a lot better, when it's actually working. btw, how would i get to the syslog to see how my RTL 8187 drops are being reported?
thanks!
Himartinm wrote:Is there anybody successfully using the PI 24/7 with a wifi connection?
Yes I have my Pi connected via WiFi using an Edimax EW7811UM wireless dongle and after initial issues with it dying after 36 hours (I upgraded to Raspbian 3.2.27, I was running 3.1.9 before) it has been rock solid ever since. Current up time ~20 days.
Cheers
Paul
Procrastination - The Thief of Time.
There is no Edimax EW7811UM as far as I know; did you mean EW7811UN? I have a clone of that device, but have not tested it long term, just for a couple hours or so at a time without disconnects.PaulCheffus wrote: Hi
Cheers
Paul
My Raspberry Pi Project Page:
https://www.flaminghellmet.com/launch/
Hipjc123 wrote:There is no Edimax EW7811UM as far as I know; did you mean EW7811UN? I have a clone of that device, but have not tested it long term, just for a couple hours or so at a time without disconnects.PaulCheffus wrote: Hi
Cheers
Paul
Indeed it is a UN not a UM, that's what happens when you rely on your memory.
Cheers
Paul
