Kendek wrote: ↑Sun Jun 07, 2020 1:30 pm
But that's not the case. The only problem is the broken UAS with some chipsets or firmwares. Which could block the OS to work properly, after the Linux kernel is loaded and switched to UAS. This is off-topic here.
Yup, the boot-loader works.The UAS problem is in Linux itself.
hwissing wrote: ↑Sun Jun 07, 2020 12:16 pm
with the acutal release one can get a working MSB-system we have been waiting for such a long time. Its a comprehensive release with machting boot software. All tested USB drives - SD-card reader, LEXAR S47 32GB, SanDisk UltraFit 32 GB - worked fine with that release.
There is no "actual release" yet. USB-MSD booting is still in beta.
For booting from the USB-3 ports with Hard Drives and SSDs one prerequisite is an ASMedia Technology chipset based USB-3 / SATA bride.
This should be outlined in accompanying documentation.
That is not the only controller chip that works, and there is no official documentation yet, because it's still in beta. Also, not all ASMedia based adapters are fully functional, because the firmware in the adapter itself is a factor. There is no way every controller chip+firmware combination can be tested, and support for that is upstream in Debian anyway.
All bridges based on Jmicron chipsets, which previously worked without complains with Pi 2, Pi 3, Pi 3+ and Windows PCs were detected, but failed somewhere during the boot process. That costs me a lot of time and a lot of money for two new bridges reported to work.
This is a problem with UAS in Linux with JMicron controllers, which the Raspberry Pi Foundation has no control over (it's upstream). And the reason they worked on the Pi3 is that the UAS driver wasn't used. Also, they didn't work property even on the Pi3, because TRIM didn't work.
There seems to be a workaround with "Quirk", wich may or may not help. But such a workaround cannot be the standard.
If you want to use a JMicron controller, quirks are your only option.
All these bridges failing at USB-3 port work at USB-2 port of Pi4 and passed SD-Speed-Test. So I think this is rather an issue of current USB-3 driver software than chipsets, which should be solved in the near future.
Again, this is an upstream problem with Debian, not the boot-loader, and not anything the Raspberry Pi Foundation is doing. It has nothing to do with the beta boot-loader, or even Raspbian.
In my setting not even the USB-3 hub of my iiyama monitor is detected at Pi4s USB-3 port, but at its USB-2. There it is reported as an additional "Genesys Logic, Inc. 4-port hub" with the same ID as the Pis.
USB 3.0 hubs are another issue altogether, and yes, they can be problematic, but that has nothing to do with the boot-loader or Raspbian, it's a problem with the hub (some only work correctly with Windows or Mac OS).
