add log file to /var/log/
Posted: Wed Jun 03, 2020 9:11 pm
by JMK8
I have an application that writes to a log file. I create (via sudo touch) a blank log file (foobar.log) in /var/log/foobar.log. If I then create the following entry in /etc/fstab...
tmpfs                                          /var/log           tmpfs   size=50M,nodev,nosuid        0       2
...reboot and then look in /var/log/ I cannot see foobar.log if I..
cat /var/log
All the other log files are visible.
I cannot compute :(
(Raspberry pi4, Raspberry Pi OS Buster)
Cheers.
Re: add log file to /var/log/
Posted: Wed Jun 03, 2020 9:18 pm
by trejan
You're mounting a tmpfs over /var/log which means any existing files in /var/log such as foobar.log will be hidden and you can't access them. The other files still exists because rsyslog recreates them.
Posted: Thu Jun 04, 2020 10:52 am
by JMK8
I didn't realize rsyslog was doing that. Something new learned. Thanks for the pointer.
