- DougieLawson
- Contact: Website Twitter
Re: Notepad++
Why do you think you need it? What's wrong with Leafpad or Mousepad?
Re: Notepad++
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
Re: Notepad++
There is nothing to prevent you downloading it -
https://notepad-plus-plus.org/downloads/v7.8.6/
But based on your previous posts, you will probably not have the ability to build it from its source code...
Re: Notepad++
As it clearly states in the first page of the manual for notepad ++
and on its home page is states
Notepad++ is a text editor and source code editor for use under Microsoft Windows
so no its not written to run on linux or the pi.Notepad++ is written in C++ and uses pure Win32 API and STL
Re: Notepad++
Of course you can download it using the RPi. Then, of course, you will want to copy/move it from the Pi to your Windows desktop PC, in order to install and run it.
This scenario could very well occur in a situation where only the Pi can see the Internet. Windows, of course, should never be allowed to connect directly to the Internet.
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
Loves Linux; loves to dance.
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
Re: Notepad++
Novaspirit Tech managed to emulate Notepad ++ using qemu, wine, and chroot.
https://www.novaspirit.com/2019/04/15/run-x86-arm/
I followed the tutorial at the time, and it worked - albeit very slow on my pi3. That tutorial is likely outdated now.
Want to run Minecraft Java on your RPi? Easiest way is with Pi-Apps - just click Install.
https://github.com/Botspot/pi-apps
Pi-Apps also includes Zoom, Visual Studio, Tor browser, Windows 10 theme, and 33 more.
Over 50,000 users!
Over 50,000 users!
Re: Notepad++
Notepadqq is not quite as good as notepad++ (in my opinion - I use notepadd++ on Windows and notepadqq on linux) but is at least written in linux-firlendly source. I'm not aware of a Pi package for it, but in principle you could compile it for Pi.
Re: Notepad++
This might be interesting for notepad++ users:
https://itsfoss.com/notepad-plus-plus-linux/
Still will not solve the ARM vs x86 issue though....
Re: Notepad++
The program Geany is similar to Notepad++, with Geany you have tabbed file viewing. I personally do not use Geany, because the text is tough to read out of the box. I have to zoom in or out with the text files all the time, Geany is intended to be more of a precise text editor. With Geany, all of the lines in the text document are labelled in numerical order from start to end. Geany has numerous side windows inside the program, which reduces the size of the text editing window. Mousepad is the basic text editor that I use all the time. Using Mousepad did take time to understand the program. With Mousepad the text in the text document is large, bold, and the same color. This is how I prefer to see text in a text file.
If you were searching for text editor programs for Linux, here is a link to a online article that lists the best text editors for Linux:
Top 10 Text Editors for Linux Desktop
https://www.linuxtechi.com/top-10-text- ... x-desktop/
You can install the programs using the terminal or package manager program.
- Contact: Website
Re: Notepad++
As an option - not necessarily your cup of tea ........
If you are remoting in to your pi via ssh you can use rmate / rsub and edit using Sublime on you Windows, MacOS or Linux machine :
Good guide on that here :
https://acarril.github.io/posts/ssh-sripts-st3
I use that when I need to do heavy lifting of cut and paste on a script on the pi as my VIM capabilities are almost non existent and nano is a bit constricted in light of this.
I suppose Notepad++ is quite good looking and lots of pressy buttons, but Geany is fantastic in Raspbian / Pi OS too as suggested above. Sometimes, if you're going to learn *nixy things, you need to learn a less familiar bit of kit, but often you will find they are more user focused and actually better solutions.
Hope you land on something you like using.
much solution-ness - https://www.wildestpixel.co.uk
Re: Notepad++
I found this article to be helpful. It explains how to link your pi to a windows computer, allowing you to use Notepad++ to edit your pi files. I have not tried yet (don't get my pi until tomorrow), but the process seems painless.
https://www.dexterindustries.com/BrickP ... nd-tricks/
Re: Notepad++
Using the Raspberry Pi is an opportunity to get out of your comfort zone. This is a good thing.
Geany is what you're looking for.
| Raspberry Pi 4-8GB | 2.0GHz | over_voltage@5 |
| Raspberry Pi OS 32bit |
| https://github.com/bassamanator/raspberrypi-scripts |
Re: Notepad++
Not necessarily. It can be frustrating and disruptive when trying to be productive, having to battle tools to get the job one wants to do done. When that becomes annoying enough it can lead to the Raspberry Pi being abandoned.bassamanator wrote: ↑Thu Jul 30, 2020 5:45 amUsing the Raspberry Pi is an opportunity to get out of your comfort zone. This is a good thing.
It's not that unreasonable for people to want tools which they are familiar with to be available and working on all platforms, working in the same way. Text editors are a hugely important tool for most programmers so having to use different tools can be highly disruptive, particularly so with command line editors where how they work and command key sequences can be very different.
There is a reason I do most of my Pi development on a PC, why most of my apps have an '--update' option which downloads their latest version from that PC.
Re: Notepad++
Notepad (non-plusplus, though) comes with the "wine" download and runs native on the Pi's Arm CPUs (no Qemu or other X86 emulation needed). It is one of the very few such hybrid PEs with Arm instructions...
Not that I use or recommend it personally...
Re: Notepad++
Quite so.
Which is why one should select tools that are available and working on as a many platforms as possible from the get go.
It is not reasonable to expect people who create programs for a specific OS and it's unique API and features should also put the work in to maintain a version for whatever platform one wants as instead. It's bonus if they do or if the ability to run them on 'alien' platforms is provided by the work of others, for example Wine.
Re: Notepad++
Just tried with that plugin but there is no way to create a session as su.CMSerio wrote: ↑Wed Jul 29, 2020 8:25 pmI found this article to be helpful. It explains how to link your pi to a windows computer, allowing you to use Notepad++ to edit your pi files. I have not tried yet (don't get my pi until tomorrow), but the process seems painless.
Best method I have found is to use WinSCP and add Npp as your preferred editor in preferences then create two separate profiles, one for your pi user and one for su. You can then edit the su profile's advanced settings to include sudo su -c /usr/lib/sftp-server.
Re: Notepad++
I've got wine on my Xubuntu box and Notepad++. Seems to work fine. I think it would work on a Pi too.
Re: Notepad++
I strongly recommend exploring the text editor options available to the open source community. Notepad++ is a pretty good text editor for Windows, but in comparison to what we have for Linux it's actually kind of crappy.
Text editors are such an integral part of working with Linux, they receive a lot of attention from the developer community. The idea of Windows having a superior text editor is simply intolerable to most of us.
Re: Notepad++
For these trivially simple GUI editors: Notepad, Leafpad or Mousepad surely the differences are small enough that the average competent developer can learn to use a different one in a few minutes?hippy wrote: ↑Thu Jul 30, 2020 8:22 amIt's not that unreasonable for people to want tools which they are familiar with to be available and working on all platforms, working in the same way. Text editors are a hugely important tool for most programmers so having to use different tools can be highly disruptive, particularly so with command line editors where how they work and command key sequences can be very different.
I agree that changing to something more powerful like vi or emacs would take some investment in learning time, though they are the same on all the platforms which is a good thing.
Pi4 8GB (Raspberry Pi OS 64-bit), Pi4 4GB, Pi4 2GB, Pi1 Rev 1 256MB, Pi Zero
Re: Notepad++
I don't find the *idea* "intolerable". There is nothing that would prevent a company with the resources MS has from writing a truly superior product. However, I find the idea that that they have actually done so absurd.
Re: Notepad++
Yes you need an emulator too.W. H. Heydt wrote: ↑Thu Jul 30, 2020 7:37 pmWell... Aside from the fact that Notepad++ is written to run on an x86 hardware architecture and Pis use ARM architecture...
https://www.youtube.com/watch?v=cb-Ruos-O2M
https://www.instructables.com/id/How-to ... erry-Pi-1/
https://www.electromaker.io/tutorial/bl ... spberry-pi
Personally, I use vim in all ecosystems.
Re: Notepad++
I don't know about intolerable. As far as I can tell there is no Windows only text editor that is superior. Even MS' best effort to date, VS Code, runs on Linux, BSD and Mac as well as Windows. Sublime runs on Linux, Mac and Windows.
Of course old favorites like Emacs and Vim run on Windows now a days.
