encryption
Posted: Fri May 29, 2020 2:09 pm
by Garg435698
Is there a good summary of available options for Raspbian full-disk encryption for the Pi 4's SD card, and for any attached hard drives (e.g. for an NAS server)?
Re: encryption
Posted: Fri May 29, 2020 3:08 pm
by Kendek
I think there are two evaluable options; dm-crypt with LUKS, and fscrypt.
For performance reasons, I recommend using Adiantum in both cases:
CONFIG_CRYPTO_ADIANTUM=m
CONFIG_CRYPTO_CHACHA20_NEON=m
CONFIG_CRYPTO_NHPOLY1305_NEON=m
CONFIG_FS_ENCRYPTION=y
> sudo cryptsetup luksFormat --type=luks2 --sector-size=4096 -c xchacha12,aes-adiantum-plain64 -s 256 -h sha512 --use-urandom /dev/device-or-partition
/etc/fscrypt.conf:
	"source": "custom_passphrase",
	"hash_costs": {
		"time": "5",
		"memory": "131072",
		"parallelism": "4"
	"compatibility": "",
	"options": {
		"padding": "32",
		"contents": "Adiantum",
		"filenames": "Adiantum",
		"policy_version": "2"
	"use_fs_keyring_for_v1_policies": true
> sudo tune2fs -O encrypt /dev/partition
> sudo fscrypt encrypt /directory/path
Re: encryption
Posted: Fri May 29, 2020 3:19 pm
by dickon
Worth noting that there's no hardware crypto on any Pi SoC, so it'll all be done in software and may have quite a hit on performance. CPU-intensive workloads may be hit hard if anything is doing disc IO at the same time, for example.
Re: encryption
Posted: Fri May 29, 2020 3:23 pm
by Kendek
The Adiantum performs perfectly well here. ;)
Re: encryption
Posted: Sun May 31, 2020 7:33 pm
by Garg435698
Thanks, I'll give it a try.
Re: encryption
Posted: Sun May 31, 2020 9:40 pm
by jamesh
True but apparently the latest PIOS has this accelerated using NEON, so should be a bit quicker -would be interesting to see results.
Re: encryption
Posted: Sun May 31, 2020 9:52 pm
by dickon
Good news. Any idea which algorithms, and is there any attempt to port that to userland libraries?
It'll still have an impact, of course.
Re: encryption
Posted: Sun May 31, 2020 10:00 pm
by jamesh
No idea, Eben mentioned it in the blog post, that's all I know.
Re: encryption
Posted: Sun May 31, 2020 10:02 pm
by dickon
I must've missed that. I'll look.
Ta.
